Question about air conditioning
Old 06-27-2003 | 12:20 AM
AcuraKid_RENAMED's Avatar
Hey guys...on my Acura 03 TL, whenever i turn the a/c on by pressing the auto button....some times that micro filter button would be on by default (the one where u choose whether u want air coming from outside of car or inside), and sometimes it will be off...is this a problem or this tends to happen when adjusting to hotter or cooler air temp? I noticed this happen more when car is really warm on a hot summer day....thanks
Old 06-27-2003 | 12:32 AM
SilverUA5's Avatar
when the car senses that the interior is hot, it will recirulate the air to make it cooler faster. it's normal.
Old 06-27-2003 | 01:49 PM
pianoman41's Avatar
Yep, SilverUA5 is correct. The car does whatever it can to try and keep the interior temperature to the temp you set. Cooling recirculated air is much more efficient than cooling outside air so when the interior is really hot it will go into recirc mode for a bit (usually accompanied by high fan speed) and then once it cools down a bit it will switch back to fresh mode and drop the fan speed accordingly.
rockyboy
08-04-2024 10:35 AM
02-25-2020 09:57 AM
PortlandRL
09-14-2015 12:01 PM
datadr
09-12-2015 09:12 PM
Nicho863
09-03-2015 09:16 PM
Quick Reply: Question about air conditioning
