Qty of transmission fluid needed
Old 12-18-2003, 06:19 PM
redbox18's Avatar
2000 TL. I am planning a transmission fluid change this weekend. Wanted to pick up some from the Acura dealership tomorrow. Does anyone know how many quarts I need to buy? I won't be able to go back to the dealership this weekend, so I want to be safe and buy enough (quarts). Thanks.
Old 12-18-2003, 06:30 PM
Planning onjust draining fluid? You know that only replaces 30-40% of the fluid. If you want it all out you need to go in for a tranny flush. Just a straight drain I hear its about 3-4 qrts. Someone wanna confirm?
Old 12-18-2003, 07:47 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
if i remember correctly, amsoil, or redline was just certified for honda trannies now, i would check into which one it is and get that. and to do it your self you need to drain-fill, drive around drain-fill, acouple times to help insure you get all the old out and all new in.
Old 12-18-2003, 08:50 PM
I'd rather be driving:
TLMugen's Avatar
Lightbulb
To answer your question...
You'll need 3 quarts (actually it's 2.9 qts).
I do a trans fluid drain & fill at every oil change, I figure it's good, cheap insurance for keeping the trans healthy.
Old 12-18-2003, 09:08 PM
Southern's Avatar
2.9 quarts is for the 4-speed automatic (1999 Model)
The 5-speed automatic requires 3.1 qts of trans fluid. I would purchase 4 quarts.
Old 12-18-2003, 09:50 PM
Southern's Avatar
Don't forget to pick-up crush washers for the drain plug and fill plug.
Old 12-18-2003, 11:20 PM
kent_99TL's Avatar
3 quarts out and 3 quarts in. I will buy total 9 quarts and flush them 3 times because you cannot complete drain all the fluid out at once.
Old 12-19-2003, 07:59 AM
redbox18's Avatar
Thanks for all the replies. What exactly are crush washers?
Old 12-19-2003, 12:19 PM
Southern's Avatar
A crush washer is the metal washer which go on the drain bolt. When you tighten it is crushes slightly to prevent leaks. Since the washer crushes you are not to re-use them. Your parts person at the dealer should know which ones you will need.
cobra10363
07-23-2024 04:13 PM
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
quake97
08-30-2015 07:57 PM
Quick Reply: Qty of transmission fluid needed
