Pulsed braking vs Continual braking
Old 03-19-2003, 08:28 AM
Severin's Avatar
Question Pulsed braking vs Continual braking
I've always wondered this:
Say you're coming to a stop from, say, 50mph. Is it better for the life of you're brake pads that you:
(1) Apply and release the brakes 2 or 3 times before coming to a stop.
(2) Apply the brakes continually (keep depressed) until you come to a stop.
Assume the same the same braking distance for both.
I personally use #1: I hate riding the brakes - I always felt that the time off the brake gave the rotors/pads some time to cool.
I have no idea what the wear diffs, if any, are between the two styles. Anyone?
Old 03-19-2003, 08:33 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
if you are coming to a stop like that the only thing you are really doing is actually having to apply more brake every time just to make up for letting off. you arent letting the brakes cool down (and there is no need)with just letting off a little bit. the brakes get cooled off by driving and not using the brakes. unless you are racing down the street and braking hard at every stoplight your brakes really arent getting hot.
Old 03-19-2003, 09:56 AM
hzm82's Avatar
I know riding your brake isn't good, but I don't see how pulsing the brake would be any better. And if you need your ABS, it wouldn't come on if you pulse the brake. Also if you pulse brake, you keep biting into your rotor more often, leading to the need for resurfacing earlier then you should. Come on....you want to apply your brakes then let off (so you build up more speed) then brake again (within this time frame you are never going to cool you brake pads or rotors off)......if you want to take better care of your brake pads, don't race to the next red light and then apply the brakes. Just improve your driving style.
H
Old 03-19-2003, 10:42 AM
Don't apply and release brakes on cars with ABS.
Old 03-19-2003, 10:55 AM
TLover8888's Avatar
dont apply and release the brakes a few times...just hold down the brake pedal because pulsing your brakes isnt good for the brake master cylinder, and replacing that is way more expensive than replacing simple brake pads.
Old 03-19-2003, 12:20 PM
2ONPAR5's Avatar
Old 03-19-2003, 01:07 PM
Severin's Avatar
eheheh - I really don't mean "pulsing", I mean apply as needed for ~4 seconds or so then release; not bang bang bang.
Simply said, instead of pressing the brake the whole deceleration time, I may apply it 3 times.
Old 03-19-2003, 01:54 PM
TLover8888's Avatar
yeah, i know what you meant...same thing.
Old 03-19-2003, 01:56 PM
doopstr's Avatar
Received 2,214 Likes on 1,211 Posts
That would require too much brain power for me. I just push and stop.
Old 03-19-2003, 11:01 PM
Braindrain's Avatar
The benefits of "pulsing" the brakes is a myth. I also confirmed it with a racing instructor at a course I was taking.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Pulsed braking vs Continual braking
