prokit springs with 18's?
distinctiv_tuning
wasup ppl...i Got some prokit springs..i havnt installed them yet...i was wondering...should i install them before i get my Katana Spazo 18inch rims with 45 offset...or install the rims and then see if i need to drop....I just dont want the car to be dropped too much and then put the rims on, and have them rub.
With a +45, 18" wheel you will likely rub with the ProKit drop. It is an easy fix with a dremel and some masking tape. Line the fender lip with the tape and drive, hitting bumps, etc. You will see black marks on the tape. Hit those with the dremel. Do this only on the plastic!!! Two or three trips should do it. If you go with a 225/40/18, the rubbing will be minor. A 235/40/18 will require more work.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
