Project Upcoming 3.5L 6-Speed
#42
13.2@ 107 on Street tires
well my buddys CL 6 speed runs 13.3s so with the extra power and torque the i can definatly see 12's...i have drag radials..so cutting 1.8 60' will help..my auto cuts 2.1s now
#45
Tristate ViP Crew
#46
Goblin With A Wrench
Sorry guys i just jumped on this thread and im a total newbie (plz teach me things so i wont be a newbie for long ) what type of engine are you replacing your TL....j35? is that from a different frame? and would a RL engine fit in a TL frame?
thx for schooling guys!!
#47
What mods does he have? Timeslips?
Cutting a 1.8 60' time is going to be next to impossible. Too much weight and not enough torque down low combined with traction problems. Getting low 60's with a 6-speed is even harder because the clutch does not like to be launched hard. You need to feather it out. I believe on 16" slicks 1 6-speed car cut a 1.9 60' but he only did it once and he broke his pressure plate in the process of doing it.
As you could see from the slips I was routinely running 2.0 and 2.1 60' times. Using all season tires and stock rims.
#52
Originally Posted by CL Platano
hmmm what happened to dude who opened his mouth without knowing anything.
WTF are you talking about, i know a bit about drag racing and having cars with alot of power and to realise just because you have more power than a previous setup, that you will more than a 2 seconds faster.
For an example.......
My 94 civic Ex with the same tires, suspension and all.......
Stock B16 with 153whp/114ftlbs tq ran 14.1@96mph
Same motor with turbo with 287whp/167ft/lbs tq ran 13.0@110
NA Built B20/vtec with 207whp/154ft/lbs tq ran 13.7@105
ALL these times posted similar 60 ft times ~2.0 on street tires.
As you can see, even with 100whp more, i was only able to run a 2nd faster on the track. With 50 more all motor HP i could only break .3 seconds faster.
Of course the two higher HP setups i would have benifited more from drag radials or slicks.
Im not saying this guy wont run this or anything, and props to the CLs that have run low 13s, but keep in mind these were with bolts ons and drag radials, last time i checked, a stock CL-s doesnt come with drag radials.
ALsssso.......Im not familiar with the drivetrain on the 6MT, how will the axels and trans hold up on slicks with all this power?
Another guy asked this question as well, how will you be tuning the car?
The only way i know of would be a VAFC hack but thats terrible for tunning.
#53
You may have experience with a Civic but from what you're saying you aren't showing much comprehension for this platform.
I have never run drag radials on my CL-S. I have never run summer-performance tires on my CL-S. Always all-season 17" tires on stock rims. And I consistently was capable of low 13s.
An automatic CL-S with a 3.5L stroked motor also ran low 13s on street tires (not drag radials).
The 6MT drivetrain will hold up just fine as long as you aren't dropping the clutch.
No tuning is required with the 3.5L stroked motor. The factory ECU handles the increase in displacement just fine.
There are multiple tuning tools available for these cars however time and time again it has been proven that on a N/A set-up tuning is not required and even when the car is tuned (fuel trim, timing advance) the gains are not worth the cost of admission.
#54
E-manage can be used as well (granted no matter what you use your limited in the tunning, but it can be tuned)
#57
Like you said though, i have no experience racing, modifiying, or tuning these motors or cars, so my comments could, like you said, be VOID.
But i do know the basics on tuning and how FWD cars react to Power
#61
The the ECU and engine will compensate for the additional airflow with additional fuel.
We've been doing this for 5+years now
Ok, so the Stock ECU has what to go by for a measuring A/F ratio? a couple of Narrow band o2 sensors? Not saying this wont get the job done, but does it really provide ideal a/f ratio?
Thats awsome that you've been doing this for 5 years now with these cars, im sure i can learn alot from this forum, not that i would ever try to do anything to my TL being its my DD and all
#63
Originally Posted by DUECE_DXJ
I just thought about this...when I do the swap will have to make any major changes to my supercharger b/c I know the 6 speed kit is a little different from the auto kit?
(info thanks to mrsteve)
#64
Originally Posted by fsttyms1
make an intake extension to span about 6 inches that the auto would have had from the VSA being present, and Adjust the voltage clamp as well. Automatic kits are set at 2.84v; 6-speed kits are set at 2.93v. You'll need a Voltmeter or a Multimeter and a small screw driver to make the adjustment. Without this adjustment your car will see boost and will pull timing thus losing a TON of power.
#65
3 inch pipe. Ask mrsteve on how to do it.
#68
Tristate ViP Crew
what would I use for a extension? The esm is how you adjust the volts?does anybody know anybody in the va/dc/md area that could do the whole swap and make the adjustments to my supercharger?
#69
@ slide or die @
#70
and hows that?
#71
B A N N E D
whoever does this tranny swap. please do a complete diy pleeease. i figure by the time my tranny is shitty enough. ill be needing this info to do it myself.
goodluck type so9
people i know who've done 6 speed/ engine swap
austin (sickest TL EVER)
fattyms1
heres the list that will
inspire TL
vzuptnguyen
adamlee
typeso9
cl platano
goodluck type so9
fattyms1
inspire TL
vzuptnguyen
adamlee
typeso9
cl platano
#72
Thread Police Chief
goodluck type so9
fattyms1
inspire TL
vzuptnguyen
adamlee
typeso9
cl platano
goodluck type so9
fattyms1
inspire TL
vzuptnguyen
adamlee
typeso9
cl platano
#73
i don't know how much this may help you guys out, but here is a thread by lookinco who did a successful swap on a 3G TL.
https://acurazine.com/forums/showthr...9&page=1&pp=25
#74
Tristate ViP Crew
I aint even trying to do DIY on the swap and plus I'm just dropping it off at the shop and have him do it. He's doing another 6spd swap on a 03 TL-S right now, so there will be 2 in Jersey and soon 3 There will also be a 3.5L 6spd swap going on a AV6 Accord during the month and its boosted. When mine goes in I'll go take pics here and there but to write things up..NO WAY
#75
goodluck type so9
fsttyms1
goodluck type so9
fsttyms1
AND Please people stop whoring up threads with questions about the 6speed swap questions. Find my original thread to ask about questions there
#76
B A N N E D
i thought your thread was closed though.
i wonder how you go about asking a mechanic to swap this for you and all he has to do? do you think they would know off the bat what is needed and such? or do we have to basically show him fstym1's thread?
#77
