Programming Keyless Remote - FYI
Dunno how accurate this is but I thought I would bring it to y'alls attention:
----copied from acura newsgroup---
http://groups.google.com/groups?hl=e....earthlink.net
-snip-
Transmitter Programming
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless
reciever unit memory.(If a fourth code is stored, the code which was
input first will be erased.)
Note: It is important to maintain the time limits between the steps.
1.Turn the ignition switch ON (| |).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with
the transmitter aimed at the reciever in the passenger's multiplex
control unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (| |).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with
control unit.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (| |).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with
control unit.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 1 to 4 sec., turn the ignition switch ON (| |).
11. Within 1 to 4 sec., push the transmitter lock or unlock button
with the transmitter aimed at the reciever in the passenger's
multiplex control unit.
12. Confirm you can hear the sound of the door lock actuators. Within
1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec.,aim the transmitters (up to three) whose codes you
want to store at the receiver, and press the transmitter lock or
unlock buttons. Confirm that you can hear the sound of the door lock
actuators after each transmitter code is stored.
14.Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation with the new code(s).
-snip-
-snip-
control unit.
control unit.
control unit.
-snip-
acuratl26
04-23-2020 07:30 PM
joflewbyu2
10-08-2015 11:16 AM
SinCityTLX
10-07-2015 01:24 PM
