Preventive Maintenance
I'm will putting on an average of 20K miles annually. What type of maintenance do you guys recommended. I change my oil & filter every 3500 miles. I don't like or want to take my TL to the dealer for their visual check ripoff. I know the tranny fluid and air filters should be changed out annually but what else should I be thinking about.
acura should be able to provide a list of what they do at different service intervals in addition to what they have listed in the owners maual - follow that.
I'd also consider a coolant flush and tire rotations and alignments. Also, you may want to consider using doing a fuel system/injector cleaning and cleaning the throttle body anually.
Btw, if you're only replacing the air filter once a year you probably have a very dirty filter or are driving through very clean air. I'd check and replace that more often to ensure you are getting good mileage. If you can't see the sun through the filter, replace it.
MrHeeltoe
20
02-23-2023 01:54 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
