????? Preventitative Maintenance Questions ?????
2400 Watts in a TL...Why?
1 Post
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have purchased a TL with about 120K and I really want to keep the car up to date on the maintenance.
What should I get checked at or around 120k. I know these cars run beautifully when well maintained. But I was also warned about the cost of fixing anything isn't too cheap.
Is there any way of telling if the timing belt has been changed at 100k - 120k.
Iunfortunatly don't have a detailed record of the work done on the car but it was drivin by a 45 year old woman from new. She actually wrote down ALL the oil change dates in the manual.
Do you think I would be able to contact the dealership that sold the car and worked on the car. Ask them for a record of the work done on the car? I could tell them I would consider continuing taking the car there for it's maintenance. What do you think?
Any advise is appreciated, Thanks for Reading!
Poppin them thangs
Re: ????? Preventitative Maintenance Questions ?????
Or call Acura Canada....
the only real thing is to check to see if the timing belt and pump( coolant would be replaced with water pump replacement) have been replaced. other than that just plugs. like G-UNIT said the dealer should be able to find out what maintenance has been done (if it was at a acura dealer)
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
navtool.com
09-25-2015 05:15 PM
