Power steering mystery!!
Hey guys,
Im having this really really strange issue all of the sudden my power steering has developed a distint whine while turning and a griding/whine at idle. First thing i checked was the ps fluid. The ps fluid was full with bubbles filled up to the brim of the reservoir. When turning the engine off the bubbly ps fluid will just ooze out of the resevoir. I waited until all of the bubbles dissapeared and topped off with honda ps fluid and started the car, noise was gone did 4 complete left right turns and now the noise is back again. Ive been driving like this for the past week with no issues with the steering wheel gettting hard to turn or anything like that. There is no loss of fluid. I know air is getting into the system but before i replace the pump, i would like to know if i should be looking elsewhere as that may be te real problem because the pump it self was quiet when there was no air in the system and ive never had any issues with a stiff or hard to turn steering wheel. My mechanic said most prob it would be the ps pump or high pressure hose, how can i verify that?
2003 TL-S 160k original ps pump on it
I would try replacing the little o-ring (#23) on the hp line that goes to the top of the ps pump. The other thing you can do is buy the 3-4 little o rings for the pump and rebuild the pump yourself (very easy to do) and see if that fixes it. Also, look at the lines that attach to the ps rack and see if you can see any leaking
Others have had issues with the small little o ring on top causing it. Other times its in the pump. Typically if its on the suction side (between the pump and the res) you will get leaking in that area, especially when the car is off. Either way everything should be inspected for any signs of leaking.
99% positive it's the o-ring on the suction side. You won't see a drip of fluid escape, but you will suck in air. It will make horrible sounding noises and your fluid will get frothy and foam out of the reservoir. This usually rears its ugly head in the cold months since the o-ring gets brittle with age and contracts; this is a well known issue - the replacement o-ring is made out of a more durable material than the original as well.
SOrry to highjack your thread But I am having a similar problem
2 weeks ago I took my car to HONDA for a timing belt job. WHen they gave my car back I felt a hissing sound when turning the wheel. I took the car to them today and they told me that my power steering pump is old and is going to fail soon and that I need to replace it. So I asked why before the timing belt job It had no sound and now it does. They had no answer only to replace the power pump since car has 140 k.
So this not sit out well on me and decided to come here and read forum or ask for any ideas?
So, all you really needed was a new o-ring.
LOL, I had the EXACT experience. Took the car in for a timing belt and walked out with a horrible power steering noise. The short of it is: to change the timing belt they need to loosen the power steering pump and push it to the side. This puts stress on the already brittle old o-ring causing the seal you had to be broken.
They told me they had nothing to do with power steering when changing the timing belt, pulley and water pump. So what I need is the o ring and replace ? thats it?
this can be a DIY? or shop?
Since I was in a hurry and needed a car the next day, I picked up the o-ring from the dealer and had the shop that did the timing belt install it for me. It's a really tight area to work in and I needed it done quick - I did try but got frustrated. It's literally a $3 part or so. DO NOT let them tell you you need a new pump.
I had that issue as well and it turned out to be a leak at the steering box pinion seal. Drove me crazy as I replaced the 0-ring and then the pump (which actually was damaged from age and overheating from cavitating fluid). The steering box would suck in air while the engine was running. The way I found it was during an oil change I turned the wheels to get better access to the oil filter and out of the corner of my eye I saw a drip. If you can, raise the front wheels and saw the steering back and forth and see if there is any fluid dripping from the steering box.
