Power Steering Fluid
Old Apr 4, 2006 | 04:12 PM
yunginTL's Avatar
trill recognize trill
What fluid is best lol, should i just go with genuine, too lazy to search..
Old Apr 4, 2006 | 04:46 PM
yunginTL's Avatar
should i be flushin it, or drain and fill?
my fluid is just a little low...
Old Apr 4, 2006 | 04:57 PM
acutee's Avatar
just suck out the reservoir fluid and refill it with one bottle of honda steering fluid. I don't think others would suggest diff fluid besides honda.
Old Apr 4, 2006 | 05:48 PM
Just use the Honda fluid. It's not that expensive. Go to a Honda dealer, it's normal a little cheaper than the Acura dealer.
Old Apr 4, 2006 | 05:49 PM
PenancE's Avatar
what r benefits of doing it? easier turning ability?
Old Apr 4, 2006 | 05:59 PM
samkws's Avatar
Comptech Freak
power steering fluid = ATF
omg...
Old Apr 4, 2006 | 06:00 PM
PenancE's Avatar
ah ha ur right
it tis red lol
Old Apr 4, 2006 | 10:21 PM
Delirium's Avatar
Only other fluid i saw was bardhal designed for but not endorsed by honda
http://www.bardahl.com/mods/gallery/gallery.asp?action=viewimage&categoryid=48&text=&i mageid=125&box=&shownew=
Old Apr 5, 2006 | 09:00 AM
fsttyms1's Avatar
Ive had non honda fluid in mine for 150k now with no issues. I got stuff from the auto parts store that was designed for honda.
Old Apr 5, 2006 | 10:51 AM
optomos's Avatar
I=X - optomos
Same here. Ive used it in my accords to.
Old Apr 6, 2006 | 02:27 AM
samkws's Avatar
Comptech Freak
Originally Posted by PenancE
ah ha ur right
it tis red lol
read the bottle on the ATF, most of them says it can be used as power steering fluid
and the honda cars can use ATF on power steering pump
too bad it cannot be used as brake fluid LOL
Old Apr 6, 2006 | 08:39 AM
RickRoush03's Avatar
RickRoush03
well i had been wanting to flush my power steering system and i did last night. autozone was to far away so i went to acura, prob got bent over but i bought 2 bottles of power steering fluid, should have gotten 4. but it says in the manual to NOT use ATF. And the honda PS fluid was clear like reg brake fluid but thicker?
Old Apr 6, 2006 | 03:52 PM
PenancE's Avatar
really.....take a pic of the bottle..
Old Apr 6, 2006 | 04:24 PM
RickRoush03
why a pic of the bottle, its just honda PS fluid. I said in the manual, which you should have, pg 237 if i remember correctly it states not to use ATF.
also, what other PS brand are you guys using, i saw prestone and this other one specifcally for honda in a black bottle over at walmart when i was there today?
Old Apr 6, 2006 | 04:50 PM
fla-tls's Avatar
On the way!
...I got stuff from the auto parts store that was designed for honda.
You found an auto parts store designed for Hondas?
Old Apr 6, 2006 | 08:51 PM
PenancE's Avatar
TAKE A FREAKIN PIC
Old Apr 6, 2006 | 08:57 PM
fsttyms1's Avatar
No i found PS fluid at a auto parts store that was designed for hondas
TAKE A FREAKIN PIC
Of what?
Old Apr 6, 2006 | 08:59 PM
PenancE's Avatar
the bottle....of it saying
"honda/acura power steering fulid"
Old Apr 6, 2006 | 09:22 PM
kuzdu's Avatar
Styl1n
how did you flush the fuid out?
Old Apr 7, 2006 | 08:32 AM
fsttyms1's Avatar
This is what i used in mine
http://www.gunk.com/prod_photo.asp?img=LG_M2714H_6.jpg
Old Apr 7, 2006 | 08:40 AM
fsttyms1's Avatar
Disconect the PS resevoir from its holder, raise teh res then disconect the return hose (the one in lower front) to drain res (get a container to catch the fluid. , then with said container stick the return hose into it and have someone start the car and turn the wheel lock to lock a few times or until fluid stops coming out. Sut car off and reconect every thing. fill to up to the upper mark. start car run at faster idle and turn wheel lock to lock to bleed air out, top off as necessary
Old Apr 7, 2006 | 09:06 AM
yunginTL's Avatar
got pix man
Old Apr 7, 2006 | 01:47 PM
fsttyms1's Avatar
Old Apr 7, 2006 | 02:53 PM
RickRoush03
mine was of another brand at walmart that i saw specifically for hondas in a black bottle also. i have a powered mityvac off the compressor that i just sucked the fluid out, refilled, started the car, let it flow for a sec, and repeated a few times.
Old Apr 8, 2006 | 12:52 AM
yunginTL's Avatar
lol nah pic's of the process, thought someone might have just took pix doin it...
Old Apr 8, 2006 | 02:05 AM
PenancE's Avatar
meh ill do this some time soon
Old Apr 8, 2006 | 10:22 PM
RickRoush03
well the process is not difficult at all, i'd say get 4-5 bottles of "honda" power steering fluid. i started with 2, but went and got 3 more. pop open the hood, look at the bottom left of the engine bay, the container with a grey top and a red cap is the PS resivour. you can do this a few different ways, have a suction device like i have and suck the tank dry, or you can un-clamp the return line hose in the front to drain the tank, just make sure you reattach in on the refills, our get a turkey baster sucker thingy with a skinny neck and suck it out like that. once the tank is empty, refill it to the max, close the cap, start the car for about 5sec, turn it off, repeat the process until you've used all the new PS fluid. it took me a total of 20min.
Old Apr 8, 2006 | 10:50 PM
nathanli's Avatar
This is what I got out of resevoir today...I can still hear the humming noise when I turn the wheel at parking; but definitely feel better...
This is the new fluid
Old Apr 9, 2006 | 12:33 AM
RickRoush03
ya, keep going, flush it till its clear or almost like new looking again, like i said, it took me 5 containers to do it all.
Old Apr 9, 2006 | 01:36 AM
nathanli's Avatar
Yea I know, I bought 3 bottles today but too bad, dealer is closed tomorrow . I will flush a little bit more next weekend.
Old Apr 9, 2006 | 09:25 AM
RickRoush03
go to autozone, thats what i did for the last 3 bottles, or even walmart, they have honda specific PS fluid
Old Apr 9, 2006 | 03:19 PM
subtledreamer's Avatar
woooo!!
thanks for the mini DIY, shall do this over spring break... it's about time
Old Apr 9, 2006 | 09:10 PM
SodaLuvr's Avatar
Its important to use a "Honda type" power steering fluid, whether its Genuine or aftermarket equivalent. "Honda type" power steering fluids contain the necessary friction modifiers, anti-wear additives, as well as the correct viscosity for Honda power steering systems. They are NOT your typical power steering system.
An alternative to making a huge mess is to buy yourself a turkey baster and extract the contents of the reservoir every 2 days, and repeat this process about 10 times, and you will have replaced > 75% of the old fluid. This is EXACTLY what I plan to do with the GM and Toyota vehicles in my family that have 90,000/10yrs and 57,000/14yrs, respectively, on the factory fill.
Old Apr 9, 2006 | 09:24 PM
fsttyms1's Avatar
I would just do what the manual says and disconect the return line stick it in a container, start teh car turn the wheel lock to lock until no more fluid comes out shut the car off and then refill. then start the car turn it lock to lock a few times to expel the air and top off as needed (much much faster way)
Old Apr 9, 2006 | 09:41 PM
PenancE's Avatar
r u serious? the fluid is suposeto be clearish? dang...hopefully mine is the tranny fluid...
Old Apr 9, 2006 | 10:22 PM
RickRoush03
ya, thanks, isn't this just what you repeated from what i wrote? why every 2 days? drain, refill, start the car and in about 5 sec all the new fluid is replaced with the old. when your car is running, take off the cap and you'll see the swirling action of the fluid moving, its not a snails pace by any means.
Old Apr 9, 2006 | 10:33 PM
SwampGas's Avatar
/etc/car
I wish I had my manual here before I act like a newb, but does running the power steering system dry damage the pump or other components like the brake system?
Did an oil change today and I noticed my power steering fluid was at the lower level (cold engine) and reeeeeeeeeeally dark. Ew.
Old Apr 9, 2006 | 11:21 PM
SodaLuvr's Avatar
Well, the Power Steering fluid has some cleaning abilities, and you'd want to give it time clean the system.
Depends who you talk to.
IMO, as long as you don't leave it running dry for an extended period of time, I don't see a problem with running it dry, shutting it off, and immediately refilling/bleeding the system. Sure you may introduce air into the system, but you'll do the same when you flush the system as well; you have to bleed the system one way or the other.
Old Apr 10, 2006 | 08:35 AM
fsttyms1's Avatar
Thats what the Helms manual says to do. If you shut it off after fluid stops coming out and not go driving around looking for women there wont be a problem. Thats what i did about 150k ago when i had to flush it out and my PSp and Rack are still working fine
Old Apr 10, 2006 | 02:47 PM
SwampGas's Avatar
/etc/car
Ok...so...
1) Unclamp the reservoir and dump out contents.
2) Turn on the car and turn the wheel to spit out the rest of the system's contents from the return pipe.
3) Clamp the send pipe back on, fill the reservoir, turn on the car, and spin the wheel until the fluid comes out clean and bubble-free from the return.
4) Clamp the return and order a pizza.
Right?
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
