Polyurethane bushings w/ CT sways
Looking into a Group Buy for the Comptech Sways. After some searching, it appears that the Polyurethane
bushings for the front are the way to go.
Does anyone know the height of the front sway bar bracket for the 2003 Type S ?
I see 2 1/4", 2 5/8", 1 3/8" and 1 3/4". I'm guessing that the 1 3/8 and 1 3/4 are too small since the bar
is 1 1/16. Also, do you go Greasable/Non-Greasable set ?
Also where do you buy them from online ? Prices ? I saw a pair for under $15 (EnergySus.)
Plz correct me if I'm missing something.
TIA,
Scott
TIA,
Scott
CT sways come with polyurethane bushings for the rear and you use the stock bushings for the front.
Personally I find this to be very balanced so I'm not sure stiffening the front would be desireable.
Retired MOD
1 Post
Re: Polyurethane bushings w/ CT sways
Is the same for all years and type-s and non type-s.
The bushings for the front are (27.2MM) for the inside diameter (tube).
My best guess for the height is 2 1/4. I would do greasable.
TIA,
Scott
TIA,
Scott
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
08, 2002, 272mm, acura, bushing, bushings, cl, current, photographs, poly, polyurethane, poplyurethane, tl, tls, transformer
