play in the rear wheels
well luckly my rims arent warped, was knocked out of balance, but checked the front/rear and the fronts are good, no play, but when i grab the driver side rear at 12/6 and wiggle u feel play, same for the passenger side, but not as bad at the driver....
what would cause that? bad rear wheel bearing?
i would look at the 5 links, the ball joints and the bearing.
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/13s0k0_b29.gif)
can i take off the wheel, and use a pry bar and start looking for play? also i changed the rear bj, with a camber kit (#21) being used and did hear clunking here and there when the rear is in a steep angle/drop.......say that failed, and broke off, worst case scenario, would the whole knuckle fall off like the front?
also if it was the bearing, wouldnt it be more of a untrue spin on the wheels? rather than in and out action?
09-04-2015 08:03 AM
