PIAA fogs to Inspire switch: Need some help!
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
OK I've got the fogs hooked up and the PIAA wire connected to the 5 points on the Inspire switch (just like mr tl's diagram illustrates). The "extra" PIAA wire is tapped onto a 12 guage RED/BLK wire that I found coming from the under the steering column.
Here's what happens - when I turn on only the corner lights and press the Inspire switch the fogs come on, the green switch LED comes on and the headlights turn on?? Then when I turn the light switch from corner lights to headlight postion the fogs turn off (headlights stay on)? Plus the lower light (for the foglight icon) on the Inpsire switch stays on - even with the keys out! What the....???
Obviously I have the wrong wire. Can someone tell me where they found the proper wire to tap into? I even left a msg for SNooK but he's out of the office right now![](http://www.acura-tl.com/ubb/frown.gif)
Thanks - Jake
Thanks - Jake
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Hope MR TL helped you out. ^^^^^
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
