Passenger motor mount - am I missing a part ?
Hello,
I am putting everything back together after the timing belft change and the new motor mounts.
I find something strange as I am putting the passenger one on, see pics, there is play (a lot) between the bolt that goes trhough the mount and the tube inside the mount.
Compared the old one and the new one, same diameter.
Is that normal or am I missing a part ?
Thanks !
Thanks !
2003 TL-p
consider getting Ingalls stiffy etd and setting it on a stiff setting. it works wonders, well worth the money. it should keep things from getting destroyed so fast
I don't remember that much slop in that bolt. It certainly doesn't look right to me as the entire torque of the engine would be rocking this around.
Have you compared all the old parts with the new ones ? I know, dumb question but I had to ask......
I'm wondering if you have the right bolt.
Agreed smartypants, that's why I seemed strange to me.
Old and new part are exactly the same but I was thinking maybe I am missing a part that would go between the mount and the mount to make it a tight fit
This is the part # and spec for the bolt
95701-12110-08 BOLT, FLANGE (12X110)
12mm is the shaft thickness and the 110mm is the length, so if a 12mm socket fits, its the wrong bolt. The head should be a 14mm, I think, certainly bigger than 12mm.
I can tighten it while installed on the car right?
sockr1
10-01-2015 01:31 AM
