Part number for window weather stripping
6th Gear
Hey everyone, I've been searching all over and I can't seem to find a definite part number for this weather stripping and I don't have an Acura dealer conveniently located. Can you anyone help me out? Pictures here.
![](https://i.imgur.com/GQKMY.jpg)
![](https://i.imgur.com/6k2jj.jpg)
6th Gear
Some more info here.
it's for an '03 TL Type-S and I need the Stripping/Seal that is shown in the pictures right around the corner of the driver side (left) front window. Any help of how to find this part would be much appreciated!
I just replaced the same part awhile ago. It's called the run channel and cost around $45. In your case it looks like it's not damaged but just pulled up. If you can, try pushing it down into the door until it lines up. Also, try adding silicon lubricant to the inside of the channel so the window doesn't pull it up again(although you might need to take the door apart to fully cover the channel)
