P2R Accord Dyno with stock J32A2 Engine
Not a TL but TL engine at least
P2R Power Rev Racing
FARA MP2-B Race Car
Stock J32A2 Engine
P2R 4 Inch Intake
P2R Throttle Body Spacer and Thermal TB Gaskets
P2R Bored Throttle Body
P2R Ported Intake Manifold
P2R Thermal Intake Manifold Gasket
P2R Ported Runners
P2R Custom Header
P2R Custom 3 inch Exhaust
Tuned on AEM EMS
302 Hp & 277 Tq
Video
http://www.youtube.com/watch?v=VAxZv-nbdsM
FARA MP2-B Race Car
Stock J32A2 Engine
P2R 4 Inch Intake
P2R Ported Runners
P2R Custom Header
Tuned on AEM EMS
302 Hp & 277 Tq
Video
619rcr (07-17-2021)
Nice. I need a AEM EMS so i can tune mine.
2000 acura tl FPR
It might not work with yours Kris since you swapped over cam gears and sensors and whatnot.
http://www.aemelectronics.com/Images...%2030-6051.pdf
I'm going to see about removing richie's harness and seeing if maybe that'll get me past 3k RPM.
B A N N E D
FARA MP2-B Race Car
Stock J32A2 Engine
P2R 4 Inch Intake
P2R Ported Runners
P2R Custom Header
Tuned on AEM EMS
302 Hp & 277 Tq
Video
FARA MP2-B Race Car
Stock J32A2 Engine
P2R 4 Inch Intake
P2R Ported Runners
P2R Custom Header
Tuned on AEM EMS
302 Hp & 277 Tq
Video
and when will you be willing to sell me a set of said headers... (with equal length tubes)
Whats up with RDX owners?
Great numbers. So are the heads not ported/polished? I wonder how much of those gains are from the headers and how much is from the EMS. Full 3 inch exhaust cant hurt either.
B A N N E D
normally, but they probably have the car setup to be extremely tail happy, and by putting the spoiler on, they are able to control the tail happiness, while also taking some of the forces off the front suspension/tires, so they can do even more work of turning the car (basically with out the spoiler, the rear end would come around like there was no tomorrow)
B A N N E D
so you gotta add downforce somewhere
and to tell you the truth, i would not be surprise at all if they where not running a front sway bar at all (or a very thin one at that)(or if they had rear springs approaching/exceeding the stiffness of the front springs)
basically it just comes down to how the car is setup, if the rear spoiler is worth while or not
Yep, when i drop that in i may not take the time to swap the manual sensors in and put the auto sensors in, and get that to tune. If he got that much from that i should be 30+ more hp than that when done
basically yes, it's a balancing act for neutral steering (and it is very hard to get a whole lot of downforce on the front to begin with anyways (yes canards and a front splitter do add some, but only so much though)
B A N N E D
not saying that it would not, just that it was another way to get the car to rotate easily (and maybe some consider it being a upgrade with a smaller one )
and there is a point where you can overdue swaybars, but it's more pronounced on the rear especially when they lift the inside rear tire (and really should be looking at stiffer springs (or a spoiler to try and force that back end back down)
B A N N E D
edit: and the only thing i have done to the front swaybar, is urethane bushings
