over heating after intake installed
Old 07-28-2008, 06:12 PM
Kooza_K2O
Kooza-K2o's Avatar
i have one of those universal advanced auto part intakes i installed every thing correctly im guessing. there were these 2 hoses in the stock filter box connected to a mini radiator of some sort. i just connected thoses 2 together.im wondering what is that small radiator for in my intake and since i joined the 2 pvc's together will my tl be ok it a 99 tl stock first mod intake ..Thank You
Old 07-28-2008, 06:19 PM
kabota's Avatar
Just a tip when you post, please use a little better English so its easier to read.
So your overheating?
or your asking about if you will over heat? Cause that answer should be no.
Old 07-28-2008, 06:25 PM
I got the Shifts
phee's Avatar
you forgot to refill your radiator resevior when you spilled all the green stuff installing your intake. problem solved
Old 07-28-2008, 06:27 PM
Kooza_K2O
Kooza-K2o's Avatar
i removed the stock intake from my car. I attached the 2 suction hoses into a 3way outlet and traveled it into the main intake hose . In the stock intake under the filter there were these separate 2 hoses that had cooling liquid in them going into a small box (looks like a 3x2 radiator with a air flap vent ) i disconnected the clips off the box and into each other so there is no mechanism in between them now..they just sit freely under the intake but now when i turned the car on every thing looks fine i test drove it but when it sits it slowly rises on the temperture gage...
Old 07-28-2008, 06:30 PM
Kooza_K2O
Kooza-K2o's Avatar
but phee when i just joined them without that piece it doesnt do nothing? that tube was pretty hot :-/ what does that piece 2 they were small lines with the green stuff LOL they arent connected at all now..
Kooza_K2O
Kooza-K2o's Avatar
imma take some pics brb
Old 07-28-2008, 06:37 PM
Avant Garde Wheels
jjashaa's Avatar
i don't understand anything you're saying and
not connected??? uhm...
Old 07-28-2008, 10:13 PM
wham bam thank you ma'am
Rajca's Avatar
so where r the pics? r u talking about the throttle body coolant bypass? for that u just connect the two small coolant lines that go into the tb.
u know what i think i read a thread about this, fsttyms1 said that it was in his car but not sure. its their to warm up the engine faster by circulating coolant into the mini radiator inside the intake. mayb fsttyms1 will chim in
Old 07-29-2008, 12:11 AM
rob-2's Avatar
Man, we really need to improve our English classes...
All the tubes need to be reconnected.
Old 07-29-2008, 09:21 AM
TL-S driver
goldendragon576's Avatar
so where are the pictures? Did the car blow up already? Maybe we can understand the pictures more.
General rule of thumb...when your working on your car and you disconnect something, you'll want to connect it back before you take it for a test drive.
Old 07-29-2008, 12:31 PM
Kooza_K2O
Kooza-K2o's Avatar
how do i post them up?
Old 07-29-2008, 04:35 PM
Kooza_K2O
Kooza-K2o's Avatar
Old 07-29-2008, 04:36 PM
Kooza_K2O
Kooza-K2o's Avatar
Old 07-29-2008, 04:41 PM
Kooza_K2O
Kooza-K2o's Avatar
Old 07-29-2008, 04:46 PM
Kooza_K2O
Kooza-K2o's Avatar
Old 07-29-2008, 05:43 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
fsttyms1 is on holiday- away from the computer
He sent me the Answer Man tshirt to wear, but I dont know what to say on this thread!
Old 07-29-2008, 06:10 PM
Avant Garde Wheels
jjashaa's Avatar
uh.... let me try....
sorry, no photoshop at work... but i think your breather line is either A) sucking up coolant.. or B) no sucking up anything??? hahah.. somebody probably can actually correct me...
Old 07-29-2008, 06:14 PM
Avant Garde Wheels
jjashaa's Avatar
god im so confused.. soo messy i can't even tell whats what........
Old 07-29-2008, 06:17 PM
Avant Garde Wheels
jjashaa's Avatar
and remove your air box resonator down there.. lol.. and your filter is...... small. hahah. makes it....... out of place.................
Old 07-29-2008, 06:29 PM
dsickles's Avatar
that looks like your heater core, I dont see why you would have to get into that to do an intake.
someone please correct me if im wrong.
Old 07-29-2008, 08:17 PM
Kooza_K2O
Kooza-K2o's Avatar
the last pic are 2 hoses connected to the hose that goes into intake they are both getting air ...the second to the last has coolant going through them ..they were connecting to the device shown on post 13...i dunno what i did but i need to get a bigger filter i know maybe the twin one of off ebay
Old 07-29-2008, 08:55 PM
Avant Garde Wheels
jjashaa's Avatar
stop going cheap imo...
go get a good filter and you'll be set.
Old 07-29-2008, 11:03 PM
slobalt defender
Hockeyman's Avatar
wow...get an intake meant for your car and not some cheap vatozone garbage. I can't tell what is what with all that mess if wires and you routing the new line using the old line.
Old 07-30-2008, 11:02 AM
Kooza_K2O
Kooza-K2o's Avatar
Do u guys think maybe that device in my stock intake was to add more cooler air to my engine and because cooler air came from the bumper . now it just sucks in hot air from the engine!!??!!!??!!??!
Old 07-30-2008, 11:25 AM
Avant Garde Wheels
jjashaa's Avatar
uh.. no.
that device is a heater for cold conditions.. or so i think it is...
and hot air.. well.. you have a warm air intake.. (short ram)... nothing you expect out of it except warm air.. remove that intake resonator first...
Old 07-31-2008, 01:22 AM
n1njai's Avatar
I think I know what he's getting at. Well, the two hoses you pulled off the mini radiator needs to be put back together, What you can do is you see the almost like a twin hose but separated together connecting the two pipe lines to the radiator? Take that and connect them together, those would be the only two wires, everything else should be taken out. Refill your coolant stuff to.
Old 07-31-2008, 04:44 AM
Rajca's Avatar
hes right, the breather tube has to be connected to the intake pipe. it vents out gasses that build up inside the engine. i dont know where you exactly connected it in the pic, but u better hope that u got no coolant in your engine , check the dipstick.
Old 07-31-2008, 10:51 AM
Volks FTW!!!
LeeDan00's Avatar
dude seriously take my advise PLEASE!!! get ride of that piece of sh*t short ram and invest in a CAI. you'll have much better breathing for your car instead of sucking up hot engine heat. that's the ugliest piece of sh*t intake i've ever seen. your stock air box is better than what you got.
that last picture just doesn't look right. the hoses aren't connected correctly. one end is supposed to hook up to the intake tube, not to each other.
Old 07-31-2008, 11:55 AM
Avant Garde Wheels
jjashaa's Avatar
yea.....
check out that hose coming from the side of the intake. you see?
those two hoses you connect together with that metal connector piece isn't right.
for the bottom section (fluid) you should have them connected to each other. use one of these bad boys.
and then get those other hoses on top and you can see from my intake..
Old 07-31-2008, 12:14 PM
Not just another newbie!
TL2498's Avatar
Looks to me like you have bypassed the intake charge pre-heater (warms the air for better fuel economy) and in doing so, have introduced an air bubble into the cooling system. Use one of those connectors^^ to hook the two hoses together and the bleed the cooling system to remove the air. That should fix the overheating issue.
Old 07-31-2008, 12:52 PM
02CL-TypeS's Avatar
wow how much did you pay for that? It isn't worth more then $1. You really need to take better care of your car. Atleast get a cheap ebay intake meant for our cars. BUT NO MATTER WHAT INTAKE YOU GET, PUT A K&N FILTER ON IT! Cheap filters let a lot of debris into your engine...ruining it. All a short ram intake is gonna do is sound like a UFO and decrease performance vs the stock intake
Old 07-31-2008, 01:53 PM
Kooza_K2O
Kooza-K2o's Avatar
i was told that the reason it was overheating was that that line with coolant was for the engine head and it was getting hot air that didnt cool down..i put the stock back on now :-/ it had alot of air in it when we pulled the cap off it was like a volcanoe ...not overheating anymore though )
Old 07-31-2008, 02:37 PM
02CL-TypeS's Avatar
if you want a cheap intake off ebay search the for the seller "xrteam" That ebay intake is the only one that I would recommend, but you still need to replace the cheapo filter with a K&N or AEM filter bringing the cost up to $100
Old 07-31-2008, 05:48 PM
Kooza_K2O
Kooza-K2o's Avatar
he doesnt have a 99 though and also if someone can scan their instructions ??,,...can i get instructions from any one on how to install their intake?? Thanks
Old 07-31-2008, 06:14 PM
02 WDP type-S Navi
importvizion's Avatar
I have a 02 and so does my brother but, I know for a fact we don't have this hose by the intake box, I dunno why you'd want a short ram anyways it just sucks up hot air form your cabin. Even the stock intake sucks in cooler air than that short ram
Old 07-31-2008, 07:12 PM
Avant Garde Wheels
jjashaa's Avatar
99-03 tl-p are all the same as intake headers exhaust spacers... blah blah blah.........................
have fun
Old 08-01-2008, 01:18 AM
n1njai's Avatar
Eh...i'll see what i can do tomorrow....
Old 08-01-2008, 09:05 PM
.a BUM with SMG...
azn_xxxd's Avatar
Hey guys, am i doing this right, this is homemade customize pipe and k&n filter.
Old 08-01-2008, 09:11 PM
Rajca's Avatar
^um ur still sucking in hot air. i dont under stand why ppl can just spend some money and buy an actual cai that's made for our cars and is a well know company, or at least and ebay one for the time being
Old 08-01-2008, 09:39 PM
.a BUM with SMG...
azn_xxxd's Avatar
so it would be bad if sucking in hot air ? i know this is stupid but i gotta ask. Im new man. So what brand would u reccommend?
Quick Reply: over heating after intake installed
