Ok need some help!!!
I rplaced both headlight bulbs because the right side was out. They both came on for a bit and now the right one is out again...When the left is on I hear a humming sound when I put my ear up to the light but on the right there is none..I searched and searched on this site....Which could it be?ballast or igniter I checked the fuses and what not just curious if anybody knows
Porkchop Sandwiches!
You may wanna check the fusebox under the hood, when a ballast starts to go bad it can blow the fuse, but even if changing that fuse fixes the problem it wont be long before the ballast will fry out completely.
