Offset number????
O.G.
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Sorry for the stupid question but how do I find the offset number? ![](http://www.acura-tl.com/ubb/confused.gif)
And what is it and what does it do?
BTW, I have 215/45/17x7 tires/rims.
Thanks guys!
Thanks guys!
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
The offset is the measurement (in mm) away from the centerline that the mounting surface (behind the lug bolts) are. In more detail, looking at your rim from the top view when the tire is on the ground. The center line parallel top the outside face of the rim is zero offset. from that line, you measure to the mounting surface (inside rim). That would be the offset.
Usually, the rim will have that info inside the rim when you take off from the car, you should see it. Hope that helps!
neuronbob
23
07-16-2019 10:48 AM
emailnatec
29
09-28-2018 04:27 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
