Odd Low beam issue
Hey all, first time poster. I bought my very first Honda/ Acura back in August after giving up my beloved 2003 4Runner SR5 V8. Liking the car so far, even though I've had a few issues with it. Coil pack gave out, Pass Side Ballast (I think it was the wire which I think is the ignitor on these cars), pass window & drivers rear don't roll
Up or down, still have a few tests To do but I'm almost sure it's the motor or regulator. But anyways, replaced the ballast and when I changed the oil, well the drain plug was the end of a spark plug. Got a new drain plug installed and all was well. Anyways, onto the headlight issue. If I'm driving at night and stop, turn them off and go inside for more than 1-2 minutes, they come back on just fine. But if I leave them on, let them go off with the factory timer, and then forget something, loading groceries or something and they time out, if I Unlock:thumbsup: it before they "cool Down" neither will come on or sometimes only 1 will come on until I wait the 1-2 minutes, then they'll both Come back on as normal. It seems like It's usually the passenger side that doesn't come on, but rarely is it the drivers side unless I turn them off and back on, then it seems the drivers side needs to cool down. It is a 2003 TL Type S. TIA :thumbsup: |
You need to test the hid headlamps individually one at a time by triggering them at the headlamp's relays. If they activate right when you power them, then you have another issue going on. Could be the timer for the headlamps.
Pax windows, check pax fuse box - fuse #8 & 16. |
I've had the similar issue with just my left side low beam. It'll come on about 2-3 mins sometimes more if they don't turn on right away... I bought the bulb and was opening it up when i found the black case (has electrical shock warning and wires connected to is) was just hanging there with the screw... (because I bought the wrong bulb - highbeam bulb)...
It took a while with a lot of muscle to get that black box in the notches and groove and locked the box in place, screwed in the hex back in and its been about 2 weeks and I haven't had the issue yet... Try to see if those are lose - maybe that's a fix... |
^ I believe the part you're talking about is call the igniter.
do what the rest of us do and give up on the 10+ year old HID technology!
spend 60 to 200 dollars depending on choice of aftermarket suppliers ...hidextra to morimoto get a `kit` with 35 watt ballast and 5000k color bulbs Everything is just a parts swap- no wiring upgrades needed, can leave stock parts in place and remote mount the new ballast!! Bonus! the new parts are waterproofed in a way the stock ones never dreamed of solve your problem once and for all! |
personal tip: dont use the timer feature on the headlights
Originally Posted by 01tl4tl
(Post 15630016)
(Post 15630015)
Originally Posted by sosoyoyo
(Post 15624383)
Originally Posted by Atlanta_TypeS
(Post 15637588)
I rather like the auto-off timer. I like being able to get out and walk to my door with the lights still on and have them automatically come back on when I unlock it. It gives the car a little more premium feel. :thumbsup:
(Post 15637759)
it's also what ruins the ballast because of the constant on and off.. :2cents:
