NEW HID's
Old 04-22-2004, 07:52 AM
idqrocks's Avatar
NEW HID's
Whatssssup,
One of my headlights went out. And I am currently
TOTALLY broke!
Are the HID's on Ebay for around $125 crap?
And do I need to buy D2r or D2S?
Word!
Old 04-22-2004, 08:20 AM
Bxscig's Avatar
For OEM you can probably get it a littler cheaper than $125. You would need to get D2R for direct swap. D2S you will have to modify a little so go with D2R.
http://suvlights.tripod.com/suvlight...enon-Bulbs.htm
Here it is $125 but I am sure that you can find it cheaper else where.
Old 04-22-2004, 10:52 AM
NYDesi80's Avatar
You should be able to pick up a pair from ebay between 75-100 shipped, for replacements, I've seen that.
Old 04-22-2004, 04:03 PM
Bxscig's Avatar
Oem?
Old 04-22-2004, 04:16 PM
idqrocks's Avatar
So what are best ones to get?
And how much are they usually?
Just in case I win the lotto or pimp myself out so
I have the $$$
:smokin:
WORD!
Old 04-22-2004, 11:01 PM
Tatewaki's Avatar
get 6000k
Old 04-23-2004, 07:03 AM
Purchased: April 28, 2001
edgalang's Avatar
Originally Posted by idqrocks
Whatssssup,
TOTALLY broke!
Word!
First off FIND OUT if its the bulb or the ballast or the ignitor! I THOUGHT one of my bulbs burned out so I purchased a set of Genuine 6000k bulbs only to find out that it was the BALLAST's fault.
Also...which bulbs do you have? Certain years/makes will have Philips, while other may use Oshram. A quick search on e-bay for a used Philips D2R bulb is only $40. But...I have 1 of each just in case.
Old 04-23-2004, 07:40 AM
idqrocks's Avatar
How do I narrow it down to the bulb or the ballast?
Swap with my good bulb?
Is it easy to exchange bulbs?
thanks
WORD!
Old 04-23-2004, 07:52 AM
On the way!
fla-tls's Avatar
Take the bulb that works and plug it into the other socket. If it lights, you know it was the bulb. If it doesn't, it's the ballast or ignitor.
Old 04-23-2004, 07:59 AM
Bxscig's Avatar
Yeah swap it with a good bulb with the side that is working, it isn't too hard to do... just becareful and take your time.
Old 04-23-2004, 09:09 AM
car_lost's Avatar
DO NOT touch the bulb with your bare hands. you can grab it by the base and stuff, just dont touch the actula bulb. it will mess them up. so be careful.
Old 04-26-2004, 07:51 AM
idqrocks's Avatar
Ok,
I'll gave it a try tonight.
WORD!
Old 04-26-2004, 11:32 AM
find yourself a used replacement on ebay.. 40-50$$?? d2r, theres no sence of buying a new one unless you get the pair.
MilanoRedDashR
10-08-2015 10:30 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
Quick Reply: NEW HID's
