New to the forums! 2002 Acura TL headlight wiring issue! :(
I was trying to get my daytime running lights and my foglights to function at the same time. I took apart the fuse box driver side panel and the trim underneath the steering wheel. I disconnected the wires from my fog light button to try to splice my foglight wire to my daytime running light wire. Instead i spliced the wrong wire, nothing happened, everything was fine, i took it apart again. I then spliced the correct wires but i didnt puncture the foglight wire enough so that didnt work. However in the process i think i pulled too hard on the string of wires behind the fog light button. Now my drivers headlight flickers and turns off, my fog lights work but flicker first, my daytime running lights work, my drivers side high beam is also not functional, and my dashboard no longer displays an indicator light that my high beams are on. My passanger side headlights all work fine. The fuses look fine, the bulbs are fine, it must be a wiring issue. How do i find the wire i pulled, and how do i fix it?
2002AcuraTL (07-06-2016)
04-13-2016 07:27 AM
BoricuaTL
04-08-2016 01:08 PM
