Need your advice...
05 C230K & 09 135i 6MT
I think it's the transmission...
J/k I figured I'd beat the posters that will undoubtedly blame the transmission to the punch..
I agree that you should start simple. Have the tires balanced and inspect the rims to see if any are damaged. If the balance doesn't help and the rims are fine, get an alignment. If that doesn't work, then look into bearings and CVs.
I thought that either the wheel bearings or CV joints would make a whole lot of noise rather than giving you a sense of vibrations.
If you drive hard, I would look into the brake parts first, pads or rotors then move on to other parts.
Our Odyssey had the same problem last fall, in this case the rotors are warped, minivans are heavy and of course the manufacturer put the same rotors as in 2G TL.
motor mount or tire
Originally Posted by fsttyms1
motor mount or tire
ditto, was just gonna say that.
i actually need to check my mounts.. i know one is broken, if not more.. girls don't care much for speed bumps..
how and where can i check the mounts... i know of the front hydraulic one, that one is fine... where are the other 2-3?
Topher707
21
05-18-2012 10:03 AM
