Need quick response
Need quick response
I am going to the dealer tmr for my regular 12k check-up. I would like to take this opportunity to address my problems and wonder if the following problems could be fixed:
1) There is a squeaking sound coming from the passenger side seat when driving.
2) Say u want to park (on flat road or downhill), u shift to P and apply the e-brake, when u let ur foot off the brake, the car moves a bit forward or backwards. (do u guys know what i am saying?)
3) When u open the trunk, it has a creeking sound.
For #2, after you set the brake and put it in Park and let it rest where it wants to, put it back in drive and leave the parking brake on. Try to drive away. Does it have any resistance in hold the car back? If not you'll either have to push on the parking brake brake pedal harder or get parking brake cable adjusted or replaced.
If the pedal is set hard enough AND the cable isn't defective, that car shouldn't move at all.
I just got my car back. The dealer said it's not the seat which is causing the noise, it's the sunroof. (???) They eliminated the noise by putting tape on that. I dont trust them, but I will test my ride to see if there is still that noise.
It is not the sunroof (at least on mine). I have actually narrowed it down to the area around the side airbag on the passenger side.
I have also confirmed it is not the seatbelt or seatbelt mechanism.
Let me know if this noise comes back. This is really annoying as it is the only squeak or rattle I have in the whole car.......
ULOOZ
The squeak could be comming from the sunroof seal. Theres a TSB on that ,or I have seen the seal lubed with "Shin-Etsu" grease to get rid of the noise. The trunk springs need grease at the contact points. Is someone sitting in the seat when it squeaks? The seat buckle may be rubbing against the frame.
If you lightly tap around the side airbag cover with your fist, bingo, squeak!
Or if move the seatback, back and forth with no one in it, again squeak. I have no doubt that it is coming from something around the airbag. I know the sunroof does not squeak with the car sitting off, not moving in the garage. It is definitely in the side of the seat.
Also, no accidents or other repairs have ever been done to the car.
Beats me, but I have not gotten agitated enought to take it to the dealer for that issue yet.
ULOOZ
I have heard of the frame itself squeaking...and on my fathers '00TL his seat cover clips were squeaking against the frame. These clips can be secured down to the support wire by removing the seat back cover(you break the clips for the cover getting the off) then slip a tie-wrap around the seat cover internal metal rod , where the metal clips hold, then to the wire frame. Sorry if it's confusing...its really an easy fix. Don't have a camera to send pics. This repair will work if it is from those metal retaining clips. Pull the rear cover off , then replicate the squeak so you can pinpoint where its from. Goodluck.............
rcs86
08-02-2016 06:52 PM
