Need instructions to program a new alarm pad
Received 1,080 Likes
Storing transmitter codes:
The codes of up to three transmitters can be programed into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the door's, the hood, and the trunk are closed.
- Turn the ignition switch ON (II).
- Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver in the passenger's multiplex control unit.
- Within 1 to 4 sec., turn the ignition switch OFF.
- Within 1 to 4 sec., turn the ignition switch ON (II).
- Within 4 sec., turn the ignition switch ON (II).
- Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again. The keyless receiver's now in the programming mode. You must push transmitter lock or unlock button of the first tramsmitter again program that transmitter.
- Within 10 sec., aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
- Turn the ignition switch OFF, and pull out the key.
- Confirm proper operation with the new codes(s).
My "P" SpAnKs YouR "S"
Between each step, wait about a couple of seconds. Also note that it doesn't matter in any of the steps if you use lock or unlock. Just hit one of them.
Repeat the following set of steps:
o turn the ignition switch on. (Note: This is the III position, and you do not have to start your car)
o push the remote lock button with remote aimed at the rec. in the passenger multiplex unit. (This is by the glove box).
o turn the ignition switch off.
• turn the ignition switch on.
• push the remote unlock button while aimed at the rec. You should hear the locks click.
• push the remote lock button.
• within 10 sec. aim the remotes (up to threee) that you want to set at the rec. and press the lock or unlock buttons. When you do this each remote should be locking/unlocking the doors.
• Turn off the ignition and remove the keys.
