Need help with timing belt noise
Hey guys my 2002 tl type s has had a wobbling sound coming from the timing belt area around 2000 rpm but as soon as I go over that it goes away, any ideas? Timing belt tensioners? Gears? Timing belt wear? I replaced the crank pulley and it got rid of some vibration but I’m still getting the noise and it’s decently loud. TIA
so I pulled the crank pulley off again and found out that the pulley has been grinding against the oil pan and the plastic cover for the timing belt, is there supposed to be a spacer for the crank pulley?
2) The Link below shows what should be the order of parts for the crank pulley:
https://www.oemacuraparts.com/v-2002...ton-crankshaft
1) Is the new crank pulley aftermarket or OEM?
also is the belt guide supposed to fit over top of the spline that the pulley sits on
If you don't have #13 (timing belt guide plate), then that could be your issue. Make sure to install it, in the order the instructions display, with the concave surface facing out.
Good Luck.
el.profe
02-20-2020 06:26 PM
Gwaks
08-11-2013 08:09 AM
kaushiknair
05-15-2013 02:44 PM
JORTS
10-14-2009 11:21 AM
