need help with footwell lighting ASAP
B A N N E D
1 Post
im puttin LEDs in my footwells and i was wondering if theres anyway to wire it to my parking lights from the inside. i have a switch if worse comes to worse ill wire the switch. wheres a good power source and ground i can tap into with out taking apart alot of stuff to get to it?
any quick responses will be appreciated
thanks
thanks
slobalt defender
if you wire it to your headlight fuse, the LED will come on when your parking light and headlight is on.
291hp & 245 tq @ 3.5psi
Tap into the domelight fuse is the easiest way to do and you don't need a switch. The light will turn on if you hit disarm the alarm or every time you open the door. The light will automatic turn off few seconds after the door is close or put the key in the ignition.
https://acurazine.com/forums/showthread.php?t=134540
2Poor 2Furious
Go to an autoparts store and look for an "add a fuse" circuit. It takes an existing fuse and adds an extra fused wire out. You take the fused wire out and use that to power the LEDs.
Oh and fyi, you should shave the LEDs to get them to disperse their light better. Grab a dremel or some sandpaper and scuff up the tips.
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Skirmich
09-15-2015 06:41 PM
Billu99tl
09-13-2015 11:30 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
