need help fast
Old 06-26-2003, 02:29 PM
falsecracku's Avatar
need help fast
my air condition is not working. it turns on and everything but theres no air coming out of the vents. when i start the car it turns on for a few seconds and it shuts off. i dont get it. anyone had this problem before. what should i do
Old 06-26-2003, 03:13 PM
TLs2003's Avatar
Check your fuses that's related to A/C and Heater. You will need to check the fuse boxes under the hood and inside the car.
Or just take it to the dealer especially if its still under the warrenty!
Old 06-26-2003, 03:27 PM
Flyin' and Drivin'
Comet2404's Avatar
Nope.... never had a problem with A/C... but make sure you check for fuses and shorts or whatnot... but definately take it to the dealership? You never not want to have A/C in the summer!!!
Old 06-27-2003, 12:00 AM
2007AcuraRL's Avatar
The AC compressor will shut down if there is not enough refrigerant (R134a) in the system. This protects the compressor from burning itself out. Its a normal event, but it means you;ve got a leak somewhere. It could be a hose, the condensor, or a seal in the compressor. Bring it to any competent ac shop and they can pump in a leak detecting dye which will show up under ultraviolet light. You can take it to the dealer too, but they probably charge higher labor rates than anywhere else. I think my dealer is up near $90/hr.
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
Frathora
09-28-2015 11:29 PM
Froid
09-27-2015 06:16 PM
Quick Reply: need help fast
