Need Brake Instruction Help
Old 06-11-2004, 09:44 AM
CdogTL's Avatar
Can anyone please provide guidance, instructions or a link on how to remove and replace brake rotors on a 2001 TL? I have changed pad before but never rotors.
Thanks,
C
Old 06-11-2004, 10:40 AM
Senven's Avatar
If you have changed pads on your car, there is not alot more to it then that.
Remove caliper as usual, remove pads, remove the two bolts holding the caliper bracket and remove it. Rremove the phillips head screw/s from the rotor, might have to use an impact driver to break those loose. Pull rotor off and thats it, do the opposite for install.
Good luck
Old 06-11-2004, 12:22 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Good luck
yes thats about it with adding to make your life easier get a impact screw driver (not a air tool, you hit it with a hammer and it turns the screw while applying the force to keep it on the screw) other wise you will more than likely end up stripping the screw head out with out one
Old 06-11-2004, 01:28 PM
tweedle99's Avatar
Check out this link w/ pics too.
http://www.abunchofcars.com/diy_page...frontrotor.htm
GWEEDOspeedo
01-15-2016 10:39 PM
gatrhumpy
19
12-31-2015 04:22 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
thegipper
09-28-2015 01:01 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
Quick Reply: Need Brake Instruction Help
