Need 99' Keyless Entry Remote Programming
I got 99 Problems
HEY TL MEMBERS .DOES ANY BODY HAVE OR KNOW THE REMOTE PROGRAMMING FOR THE ALARM. MINE RESET I NEED TO GET IT WORKING AGAIN.
Programming Steps
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock buttin with the transmitter aimed at the receiver in the passengers multiplex control unit. ( I just aimed it where you put you feet if you were a passenger.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin with the transmitter aimed at the receiver in the passengers multiplex control unit. ( I just aimed it where you put you feet if you were a passenger.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock buttin with the transmitter aimed at the receiver in the passengers multiplex control unit. ( I just aimed it where you put you feet if you were a passenger.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock buttin with the transmitter aimed at the receiver in the passengers multiplex control unit. ( I just aimed it where you put you feet if you were a passenger.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter cde is stores.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
03, 32tl, 99, acura, acurazine, entry, keyless, multiplex, programing, programming, receiver, remote, sacramento, tl, unit
