Navigation system reboot?
This has happened to me twice so far in about 2 months that I've owned the vehicle...suddenly for no apparent reason the navi system just reboots!! After it reboots it comes back to the agreement and then the screen with the last address it was guiding me to. Has anyone else experienced this??
Refer to the http://www.acura-tl.com/ubb/Forum14/HTML/002164.html post. Maybe they are somewhat related.
If it happens more than once or twice a month, see if you can exactly replicate the problem. It's difficult to determine exactly how an error occurs, because so many things are happening at the same time -- map redraws, route calculations, reading off the media, GPS tracking, etc. But I remember that Alpine's software was very sensitive to input timing (i.e. they had a thread-safety problem). Make your inputs slowly and avoid inputs during the inital map redraw.
Once you've determined how you can replicate the problem, call the Acura navi dept. and leave a bug report. Unfortunately there's not much you can do about it. Unless Alpine can replicate your problem, the chances are slim that they'll ever find an obscure bug.
Also, see if you can get a free DVD upgrade from your dealer. Sometimes changing the data read from the DVD is enough to knock the bug "somewhere else" where you won't see it again. It's not a fix, but you won't have to deal with the problem.
Remember, there's no such thing as bug-free software!
From the Navi manual:
"You may find that the system occasionally 'reboots'. This is indicated by the display returning to the logo screen. A reboot can be caused by a number of things, such as entering data too quickly, or by excessive heat or shock. It does not necessarily indicate a problem that requires service. After the system completes the reboot, it should allow you to complete whatever functions you were performing before the reboot."
'02 TL-S w/Navi, Black/Ebony, Blackwood trim kit, footwell lighting, Type-S floor mats (soon!).
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
