Navigation problem
he doesnt have a security code issue- he want to use the private function of the nav--is that correct?
my 01 has 2 of them plus the general address area. Its so you can keep biz address seperate or 2 drivers private list,,whatever
the default is usually 0000 but go ask the service manager if they know different
If you disconnect the battery you `lock` the radio -which then needs its code to unlock
You can now look those up for a small fee on acura along with all the tech manuals
https://techinfo.honda.com/rjanisis/logon.asp
call acura to register as the owner- 1-800-382-2238x5 ask if any open recalls or extended warranty you need to know about
some 03 get a FREE partial timing belt job from recall- you can pay for a little extra in parts and get a $1200 job for a few hundred with new water pump and everything
try every combo of 4 same digits 1111 2222 9999
Or you can call Acura, never called before so I had to Fax/Email them a bill of sale or I think they'll take copy of the title with your name on it to prove ownership. Then they'll give you the a reset code to get into it. Really quick and easy.
there is a differance between the radio security code that you need after battery disconnect, then there is a seperate code that YOU pick for the PIN on personal address book in nav
What no one seems to know is resetting that PIN code for new owner
BoricuaTL
04-08-2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Gianni Formica
09-07-2015 08:28 PM
travr6
09-06-2015 02:11 PM
