Navigation doesn't work in cold
My navigation sysytem does not work in the cold weather, it tells me that the door is open or disk is not formatted , but it works fine in the hot weather, i never had a problem with it untill this year.
So i can't use it at all, has anyone had the same problem or know what i can do?
thanx
fred
thanx
fred
i wish it was that easy guys, i have tried both, cleaning the disk did not work and turning the car off and on doesn't work either as the system just goes directly to that message, but it works fine in the summer time!
Yes i have cecked the contacts on the dvd door and also all the wire connections in the back, i'm thinkin maybe something went bad in the unit itself. I will have the dealer check it out next time i'm in for a oil change!
Sippy Cup (x2)
Originally Posted by snowman81
Not sure what that could be but if you do bring it to the dealer ask if they have a nav tech. I brought mine in for a nav problem and they said I needed a new dvd unit. So I brought it to another dealer and the nav tech told me it was just a ground that came loose. Saved me about $3000.
Thanx for that info i sure will ask, there is no way i amgoing to get a brand new system, i don't even use it much at all to drop 2 or 3 grand on it!!
Just curious, do you have a original DVD or is it a burned copy. When I bought mine used I had the same problem when it got cold out. Went to check the disk out and it was a burned copy, I called the dealer and made them buy me a new factory DVD. Never had a problem since.
AndrewS
19
03-14-2024 06:59 PM
rockyboy
01-25-2016 06:00 PM
