NAV Conversion Help
NAV Conversion Help
Hi Guys,
I'm in the process of installing Doms converter, Blitzsafe and DVD player and need some into. I know I saw a post about removing the passenger side kick panel, but I can't find it. Also I think Dom said the converter needed an aux power as not to drain the battery? Where can I get that? I've got a hot wire running from the battery hookup on the fuse block already going thru the firewall, but either need to find an aux power or put in a switch. Help me out a little guys and I'll post a good DIY with pics when I'm done. I already mounted my player on the inside ot the little trunk door so that when I open it, The dvd player is accessable, the hidden when in use. I'll mount the remote eye up front. Thanks in advance for the help. P.S. I tried search but could only find the console removal for the blitzsafe install.
07-16-2017 08:33 AM
navtool.com
31
11-16-2015 09:30 PM
