Nav
Old 07-24-2002 | 11:09 PM
BEEBAD's Avatar
Question Nav 02 TL
Does anyone out there know if a Nav sys can be added to a non nav car ie: is the wiring harness the same and the climate control just plug into nav computer, is gps antenna already in rear glass??????? thanks I know where there is a wrecked car w nav.
Old 07-25-2002 | 07:17 AM
axeman's Avatar
The axeman Cometh
No, the 2 are not interchangeable i.e. you cant just add the nav system in a non nav car. You can however add an aftermarket system that would give you all of thefunctionality that you want. Give that a try...or buy a lot of paper maps
Old 07-25-2002 | 08:00 AM
doopstr's Avatar
Actually someone on this board has done the conversion. It was a lot of work though. Do a search. I'm sure you will run into it.
Old 07-25-2002 | 08:49 AM
bigman's Avatar
'Big Daddy Diggler'
It has been done, but i also heard that it wasnt as acurate as the stock navi. I recommend you do an after market alpine unit so that you can have nav, tv, dvd. That will save you all the money in parts and labor
Old 07-25-2002 | 11:16 AM
songoku's Avatar
BlingBling INSPIRE 32V
Asif2002 has done it!!!
Go here for more info.
Old 07-25-2002 | 11:19 AM
Do what Paul said...also, I believe that Asif2002 has another stock nav setup with instructions on how to convert for sale.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Quick Reply: Nav
