Mystery Mod @ AutoCarParts
#84
Originally posted by NBP TL
a flux capacitor wont give you power across the whole powerband. Good try though, McFly.
why don't you make like a tree, and GET OUT OF HERE!:p
#85
As mentioned, we don not have a MAF. A MAF is a Mass Airflow Sensors based system, ususally either Hot Wire type or Karmann Vortex style.
We use speed density where the values from the MAT (Manifold Air Temperature) and the MAP (Manifold Absolute Pressure) are used to caluculate density since the volume does not change.
I would not think they are messing with the MAP. The only way to see the gains they are proclaming is if our fuel maps were way off to begin with. I still feel it is ignition related. Either a new prox bracket or electrically shifting the phase.
#87
Originally posted by Bigmonkey70
Just wait and see if Electric Supercharger is BS. My brother is currently working on a project with the electric supercharger on his own Celica. He get it dyno soon.
I don't think the map sensor mod give you a linear HP gain through out. I have seen some map sensor dyno (not on TL), and there are lost at certain RPM.
From all MAP/MAF sensor replacements I have seen, a pretty much across the board performance gain was seen.
#90
Originally posted by Beiruty
Anyone knows where I can see some MAP/MAF sensor replacements dynos.....
A MAP is just a pressure sensor (motorola piezo based, probably). It measures absolute pressure only and knows nothing about the engine other than what the current manifold absolute pressure is. It's signal is normally voltage based, 1.5 - 4.5 VDC. They come in 1, 2 and 3 Bar units. I suspect that we have a 1 Bar unit, no real need to measure much over atmosphere.
People have tweaked the pressure signals on factory turbo's cars so they can raise the boost above the factory hard limit. But messing with this signal would just throw off the fueling in most cases on an NA vehicle.
Most of the gains from changing a MAF are from going to a freer flowing unit, i.e. less restrictive, which has been properly calibrated to give the same or near (maybe a slight tweak) frequency as the stock unit with the same mass of air flowing through.
#91
hmmm, same as those MAF conversion kits by www.splitsecond.com
#92
The nice thing was that you could tune it so that it didn't affect the fuel trim table (the PCM's ability to adjust for conditions) during cruise and idle. But go WOT and you could have the fueling that you wanted and needed contrary to what the factory set it at.
But since we don't have a MAF this is worthless to us. But a fun and useful device nevertheless.
#93
SO, now Snook said he will get one soon to be installed on his TL, get it reviewed, post installation instruction.....and taking pre-orders.
The question, what is the best estimate for this to happen?
Syncivic said that it could happen on or before SEMA show (End of this month)....
What is the best guess?
#94
to the experts:...does it make sense that if you increased the size of the intake runners that the computer would sense the need for more fuel hence making more power...
my thought s again are a plate that goes on top of the runners that mirror there path increasing there size ...any thoughts??? certainly a 5 min. bolt on
#95
#96
The plenmum design in the Type S is not a variable length style, it is resonance. The length does not change nor is the valve to switch between lengths.
The intake runner lengths are fixed and flow from the end tanks and turn down towards the head ports. But what does change is the aprearent volume being presented to each end tank. Our intake manifolds have what could be considered to be three chambers. Two on either side of the engine and one in between these two directly over the top of the engine 'V'. This center chamber has a butterfly valves seperating it in two.
From each end tank there are multiple paths. Of course there is the one intlet from the throttle body. There are also the previously mentioned runners to the ports. But there are also as set of openings that connect to the center chamber.
At low speed, below 3800 revs, the butterfly valve is closed essentially seperating the inner chamber and the two end tanks. As the revs climb past 3800 this valve is commanded open by the PCM. This now creates an open path between each of the two end tanks.
But it is due to this that the air pressure will vary at each end tank causing a resonance effect increasing the amount of air in the ends tanks which is now available to the engine.
Just wanted to clear this area. BTW, on variable length runner systems the long runner is used for low RPM and the short for high revs. But it doesn't apply here.
I'll try and remember to post a link to an expanded veiw of the manifold and runners system in the Type S engine.
#97
Just in case you were interested in the diagram. Warning, it is over 0.5 MB:
http://www.flwse.com/images/steve/En...32A2Engine.jpg
#99
"to the experts:...does it make sense that if you increased the size of the intake runners that the computer would sense the need for more fuel hence making more power...
my thought s again are a plate that goes on top of the runners that mirror there path increasing there size ...any thoughts??? certainly a 5 min. bolt on"
Uhm...no that doesn't make sense...because if you inject more fuel you're messing with the combustion ratio of ...1:14.7 is it? In which case you may actually get less power...and have a lot nastier exhaust...
Austin519
Austin519
#100
#101
On www.AccordV6.com They are reporting that the UNICHIP ECU Enhancer would add 25-40 HP on all the rpm range by Dyno Tuning.
Anyone Tried to have his CLS Tuned with UNICHIP.
From the improvement in performacne gains, I see it has to do with Ignition timings. I could be a sensor or a mechanical....but it has to do with the ignition timmings.
#104
#107
#109
scalbert i wasnt suggesting to increase the length, of the runners rather the diameter ,via a plate made to mirror there path of the runners ,that would fit on top of the intake manifold than the gasket then upper cover..???more air computer adds more fuel = more power similar to if the runners were extrude honed.
Extrude honing bothmanifolds would probably yield something, how much I don't know.
#110
You could increase the diameter but I couldn't say that you would gain anything. The individual runners in both the upper and lower manifolds are at least 1" diameter which is plenty, IMO.
#114
Originally posted by juniorbean
The release date is SEMA which is the first weekend in November. I doubt Tim will really be able to put up too much information before that date.....
#116
Originally posted by snook789
Yes, I should have the sample and write up on the site before SEMA
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
