My 6 speed swap thread
#122
Did you get the upper bracket made for the clutch pedal?
#123
00 ssm
That's how I did it as well. Also, I didn't tighten down the tranny mounts to the frame until the tranny was bolted to the mounts, probably common sense but you never know.
#125
3 pedals in my 99 TL
Cars been done for about a week now. Just now waiting on my new intake since I ordered the wrong one before I take it to the dealer to get the immobilizer on the ECU reprogrammed to my key so I can finally start her up. Heres a few pics of her back on the floor.
![](http://img.photobucket.com/albums/v332/azndemon11/life%20of%20a%20UA5/b42177fe.jpg)
![](http://img.photobucket.com/albums/v332/azndemon11/life%20of%20a%20UA5/2f8b97ab.jpg)
![](http://img.photobucket.com/albums/v332/azndemon11/life%20of%20a%20UA5/c8791ff1.jpg)
![](http://img.photobucket.com/albums/v332/azndemon11/life%20of%20a%20UA5/13975705.jpg)
![](http://img.photobucket.com/albums/v332/azndemon11/life%20of%20a%20UA5/5e068c99.jpg)
Car now definitely sits higher due to the new tranny being much lighter so I'm probably gonna take it down a tad in the front again once I get her up and running. then......VIDEOS in action! So stay tuned!
Oh and im gonna work on my parts list right now so ill post that right up once i get it all together
#128
I'm hoping next week. It all depends on when the intake gets in because I don't wanna start it with no intake plus it won't start yet anyways because there's an immobilizer on the new ECU that has to be reprogrammed to my key by the dealer.
#130
Here's a parts list for those of you who plan to do it in the future. Basically the exact same thing as Kris (fsttyms1) since I did the J32A2 CLS 6MT motor + tranny. most of it is from his thread.
03 CLs-6 J32A2 Engine
03 CLs-6 speed manual transmission.
03 CLs-6 Manual Engine Harness. 32110-PGE-A11
03 CLs 6 speed ECU
03 CLs-6 Flywheel 22100-PGE-026
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000
03 CLs-6 Clutch Assembly 22105-PGE-305
03 CLs-6 Rear Engine mount and bracket 50810-S3M-A01, 50827-S3M-A00, BOLT (m12X25) 90166-S3M-A00
03 CLs-6 Rear and Front Engine Dampener and bracket
03 CLs-6 Shifter and cables. 54100-S3M-A01, 54310-S3M-A01
03 CLs-6 Starter 31200-PGE-A11
03 CLs-6 Gauges
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01, & 46970-S3M-A01
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03, 50805-S3M-A03
03 CLs-6 Cup Holder 77230-S3M-A01ZA
03 CLs-6 Parking brake 47105-S3M-A04ZA and to go with it,
Spring 47537-671-670, Nut 47522-594-000, Equalizer pin 47365-538-000, Equalizer 47360-SB2-000
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
CLUTCH PEDAL 46910-S3M-A01 & CLUTCH PEDAL BRACKET 46990-S84-A01
BRAKE PEDAL ASSY 46600-S3M-A51
MASTER CYLINDER ASSY 46922-S3M-A01 & Clutch Fluid Tank 46965-S5A-013, & Clutch Hose 46961-S3M-A02
03 CLs 6 speed ECU
03 CLs-6 Gauges
#132
just noticed this post but i didnt get the upper bracket yet im going to just get an L bracket from home depot or something and just bolt it up. that would work yea? i think i seen the other Kris do that in his thread or it was one of the other 6mt guys i forgot.
and thanks Tim yea it was definitely a lot of parts but well worth all the work. total cost for all those parts ran me 3200$ shipped.
#133
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc7/301307_203726163030431_100001791456793_487990_1543701778_n.jpg)
You may have take off the clutch pedal to add custom bracket on. For more suppose i drill bolt on top part of clutch bracket.
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/314826_203725773030470_100001791456793_487989_986033795_n.jpg)
As you can see the bolted into top part of clutch bracket
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/302645_204293056307075_100001791456793_489225_620454248_n.jpg)
Nice work on your swap
#134
damb this is a crazy swap. you did a good job redoing the wiring. but you might run into trouble with that key programming? just make sure they 1st program the computer to the car..and then the key to the computer...i had trouble where i just had the key programmed to my computer and it did nothing..should run you 120 bucks.
good luck
good luck
#136
#137
good luck
good luck
#138
Here pic of my custom made bracket from 2 L bracket. Use 8M X 1.25 screw fit perfectly in top thread bolt hole ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
good luck
good luck
Thanks!
Will do! Haha
#140
Negative. Still waiting on the intake and just refilled all my fluids today. Soon as the intake gets here I'm taking it to get reprogrammed and starting it up.
#146
Sorry guys I've been busy lately and the guys who are supposed to come program my key have been lagging as well. However, the car isnt cranking over when I put the key in and turn it but I am getting the flashing green key light in the dash. I think somethings up in the wiring because from what I've read and been told it's supposed to at least crank? I thought it wasn't cranking because my key wasn't programmed to my new ecu yet but I don't know. I know it's not my battery or starter so I'm stumped at this point. I'm looking at my wiring again and there are a lot of wires unplugged but it seems there's no place for them to be hooked up to unless I did it wrong?
Also, when I plug up the battery, random things work in the car without the key being in it such as my driver side window rolls down only, my passenger side dome light and not driver turns on, cabin light turns on and dash light displays. My fuel light, battery light, abs, srs and green key light all come on and my temperature reading is at 111. I can't change the trip or turn on my headlights or wipers and my e brake and brake lights don't work as well. Those are the symptoms it's having right now
#148
Yea I'm currently doing that right now. All the grounds seem to be good it's just a bunch of connectors with no place to go. It's a big ass headache bro haha and it's frustrating. I'm gonna take some pics and show u guys what is up gimme like 5 or 10 mins to upload some. Maybe the pics will help
#151
00 ssm
Damn hopefully you figure it out soon. Thats a lot of things not connected I feel like some of those have to be the problem. I need to look at the video again slowly to see if I can pick anything out but toward the end that "black wire" you mention looks like the OBD port so that doesnt need to be hooked up to anything.
#152
Yea I think I need a new fuse box for the driver side because we managed To hook up a few more harnesses but there just isn't enough spots for all of them. Also when referring to the manual it shows there are spots on the fuse box that aren't on my current one since I have the CL manual.
#156
It's all good bro thanks for comin thru anyways. But yea I think we figured it out were pretty sure it's the fuse box cause even Kris(fsttyms1) told me the same thing that he switched it out to the 03. I don't know how I could have made that mistake and missed that part but oh well.
Yea I would be the one to buy everything except the fuse box -___- but u live and u learn
