Is my 03 TLS done for? Loud squealing from upper manifold please any ideas
I may have to cave and take my car to the dealer just to be told my engine is done for : (
Loud squealing coming from upper manifold cover, def not power steering and I just changed my pcv valve but the noise didn't go away.
When I accelerate the noise goes away. My car drives fine, no rough idle, no problems starting, no problems accelerating -- but this noise is gut wrenching. It's the loudest whistle/squeal and it seems to reduce slightly if I press down on the upper manifold cover. I verified the upper cover gasket is on properly and broke a bolt over torquing but I don't think my upper manifold cover not being on tight enough would cause a noise this loud. Any ideas? My car drives great and I don't have any symptoms of a vacuum leak, just a VERY loud audible noise which is certainly not coming from the power steering pump. It doesn't sound like a belt either. I'm at a loss for ideas.
Link of the noise is below. Any ideas would be greatly appreciated.
Latent car nut
Given your description of what is happening and how your car drives, I'm at a loss as to how you could possibly come to the conclusion your engine is done for. I cannot opine as to what the problem is, but I believe your engine has plenty of life left in it.
justnspace (12-01-2018)
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
Kyin01
1/2G MDX (2001-2013)
03-27-2011 10:19 PM
fliplyricist1
06-28-2008 08:24 PM
