Mugen Pedal Install help
Old 05-30-2003, 07:39 PM
unbeknownst's Avatar
First of all, i tried the search function and didn't find any good help. I just spent 10 minutes attempting to install these pedals. Any advice? For the brake pedal, do you use the black screws and the two tabs on the back of the pedal? I couldnt line them up worth a crap to get them screwed in. Also, what do you do for the gas pedal? Mine came with double sided tape... should i just screw them in or use the tape as well? Im kinda wary about having them stuck on there permamently if I go to sell the car. Thanks in advance.
Old 05-31-2003, 04:06 AM
NighthawkBlack's Avatar
FOr the Brake, remove the ruber pad then install the Mugen pedal with the double side stick tape and the screws that prevent it from poping out. The gas just gets screwed in.
Old 06-01-2003, 01:00 PM
accordv6's Avatar
Similar question here...........I got some pedals and the accelerator doesn't fit over the stock unit........do the stock pedals come off? I can't figure out how to get the darn thing off.
Old 06-01-2003, 02:28 PM
I don't believe the stock gas pedal "comes off".... it it just part of the entire assembly.
Old 06-01-2003, 02:50 PM
Tatewaki's Avatar
Gas pedal is the entire assembly. You can tae it off. That's why NighthawkBlack said to screw it in
Old 06-01-2003, 05:54 PM
VTECTLtypeS's Avatar
ok the brake pedal..u take the rubber off and put the mugen on....u set the metal pieces and screws behind the brake pad so that it holds it down.......
the gas one just goes on top and u drill the screws it
F-C
Motorsports News
28
09-25-2019 07:40 AM
BoricuaTL
04-08-2016 01:08 PM
Iakonafuji
09-21-2015 02:39 PM
09-17-2015 09:01 PM
TxRzrBk
09-17-2015 01:07 PM
Quick Reply: Mugen Pedal Install help
