More problems
Originally posted by BK99TL
can the injectors be cleaned without going to the dealer?
First, look at your tach, how many RPMs have you got? And does the needle shake? You may have a bad spark plug, or ignition mogule, or something else causing 1 cylinder not to work.... Most likely covered under warranty
well, brought my car to the dealer. the service manager took it for a drive. only when the car is in PARK, it starts to shake. i'll let you know what happens. he says its most likely dirty injectors cos when a cyliner misfires, a check engine light will usually come on. you know i checked my past service records and ive been the dealer every single month for the past 8 months to have something fixed.
Originally posted by AndySara
You could also have him check:
1) Idle boost controller
2) Engine mount. One of them could be damaged
ok they said i need to flush out the fuel injection($100) and tighten the valves($345)!! i was like heck no! so they are checking to see if these things can be covered under warranty. i swear i had a 1998 honda accord(100K miles) before this and never did i have any problems of these kind.
i have 59K on my car. is this normal?
:flamer: acura
:flamer: acura
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
