moisture from firewall drain plug?
Old 04-26-2004, 07:58 AM
I noticed a steady drip of water from a drain (1") hose protruding through the passenger side firewall. It created a good 3" diameter puddle in the driveway. I soaked some up with a tissue and it seems to be water. Any idea as to what this purpose is (A/C or defrost condenstation), drain for winshield run off?
Old 04-26-2004, 08:11 AM
2400 Watts in a TL...Why?
ResidualFreedom's Avatar
I would guess it was condensation from the A/C so yes it would be water. Espically if there is a tube there (likely for drainage) it's not like ther is water just drippin' from the bottom of the car.
Old 04-26-2004, 08:22 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
agreed, the car wont drip water unless there was a reason for it (i.e. it rained recently, or like ResidualFreedom stated like your A/C)
Old 04-26-2004, 11:09 AM
8th Gear
legendcoupe's Avatar
residualfreedom is correct. The tube comes from the a/c evaporator box located behind the glove box. Its purpose is to allow condensation from the a/c to drain out of the evapo box so it doesnt fill up with mildew.
Old 04-26-2004, 12:11 PM
On the way!
fla-tls's Avatar
Slightly OT:
My Grandmother used to own an old mid-80s Chrysler K car, and the drain hose from the evaporator got clogged. It filled up so full with water that when she would take a corner the water will slosh out onto the floor.
I fixed it by cutting the tip of the hose off, but it was pretty disgusting...
Old 04-26-2004, 02:48 PM
Thanks all, legendcoupe, your exactly right on the location. I had a brand new Grand Caravan one time that A/C froze up because the residualfreedom wouldn't drain quickly enough.. Gotta love this site!
Mike734
12-10-2021 01:25 PM
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: moisture from firewall drain plug?
