Mission: Locate the Creaks and Rattles
I spent the better part of the evening locating the last few creaks/squeaks/rattles in the TL-S.
I came up w/ a few more locations to check for all you paranoid owners that hate noises as much as I do:
- back seat, look up while sitting, and locate the end of the ceiling's padded lining; this is where the rear windshield meets w/ the ceiling. Pull down gently on the padding material and note whether or not you hear a "sticky" creaking. This was the source of a bunch of my noises, so I found some cotton, and stuffed the gap w/ it across the width of the window and hopefully, mission accomplished.
- Underneath the rear deck (where the BOSE woofer is mounted; accessible via the trunk) you may be able to play/jar some of the mounted gear to locate anything that may click/rattle/creak. I did this and used an appropriate fix (duct tape squares, cotton) to "mend" the issue.
Best of Luck, and lemme know if any of this was helpful.
Also:
Rattles seemingly coming from the right front dash were actually the drivers seatbelt vibrating against the pillar.
The plastic lid on the center console storage area (between the seats) was hitting the lower part causung an incessant rattle. Glued pieces of foam and this fixed the problem.
I think pretty much every rattle & squeak can be fixed relatively easily EXCEPT for the seats. Fortunately and touchwood I dont have the squeaky seats. As yet.
I understand the paranoid issue too. These are our babies and we want them to be perfect.
Rattles and noise are going to happen of course, but the solution to fixing them is all is to just buy a JAPANESE car MADE IN JAPAN. You should experience the fit and quality of a LEXUS or even some of the TOYOTAS. So solid and quiet that you are simply amazed. Every detail is taken care of. It's beautiful.
Acura TL is still overall very good, but the Ohio plant is still not as good as the one in Japan.
Our 1989, 1990, and 2 1991's Camry DX's (I4) were just the same in terms of build quality. I actually believe those $12,500.00 (brand new, great value @ the time) cars were more solid and built w/ better craftsmanship than the TL-S.
It was really a trade-off w/ me .. either I got the 2001 ES300 and had the luxury and refinement and quality, or I bought the Tl-S and finally had a car w/ some aggressively qualities, decent acceleration, and 17" rims.
Originally posted by PeterUbers
Can't agree w/ you more. My '94 Lexus ES300 was a tank -- rock solid, bought used w/ 34K miles, sold at 108K miles ... NOT ONE CREAK/RATTLE/VIBRATION/SQUEAK. Rock solid. The engined purred like a kitten.
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
