Missing Cylinders (bad coil packs) Gas mileage
im pretty sure that im gettin bad gas mileage, a cylinder or 2 is bad on my 03 tis. I'm positive its the coil pack.
does anyone know if its a minor difference or major wheter it's 1 or 2 bad coil packs.
duran492 (02-01-2013)
Yeah, as said "check the codes". There are other things that can also cause poor gas mileage and runability issues.
How many miles ? When was the last tune-up ? Have you cleaned the EGR passageways ?
Try some fuel system cleaner, check all the wiring and vac connections, maybe something simple that just needs tightened or replaced ?
Check the injectors, plugs, coils and compression if you're sure it's a lazy cylinder.
it threw a couple codes at me .. it told me i had 2 bad coil packs .. i did some research on here and someone said one bad pack can send 2 codes ..
i checked the front 3 and they are fine .. i could one get to the one far left in the back and that one is fine ..
some times when i start it "glug-glugs", then once i take off it goes away and a normal idle comes back. i have not tried and fuel cleaners at all .. but i will today! ..
You sure it's not EGR/IACV related?
Bonki' Ehrite!
OP, what codes did it produce? p030x codes?
And how did you test your coils packs?
duran492 (02-18-2013)
OculiAquilae
11-19-2018 02:24 PM
09-17-2015 09:01 PM
