Mirror Replacement!!!
i was attempting to do it using the DIY. stupid fucking shit wouldnt budge. after liek 50 mins a part of my glass started to spider web!!!! WTFFF! im guessing insurance will not cover right?!? is there ne way to get this replaced without paying???
fukin shit i shouldve just let fukin acura do it.
sorry need to vent
sorry need to vent
Are you pushing the clip up from below it using a flat head screw driver? while doing that the mirror should pop down/forward with only a minor pull. THE MIRROR DOESN'T COME STRAIGHT DOWN SO DO NOT PULL IT DOWN. DON'T USE EXCESSIVE FORCE. I have said that over and over in the DIY. Obviously if you are cracking your windshield you are using excessive force.
Depending on your insurance company and your plan, some do cover cracks on the glass.
i wasnt pullin it down. i was pulling it forward down toward the hood. yes i was pushing the clip up at the same time. i donno y my seem liek it was super glued on.
so depending on my comp they will cover it even tho i messed it up myself? its not that big its liek 2 inch cracks only seen from inside.
mike
mike
Was your car bought used or been in an accident ? I remember some1 who bought a TL that was used and it seems it was in an accident and had the windshield replaced. The bodyshop used a cheap front windshield from china and not OEM. So the bodyshop just epoxy the mirror onto the car instead of installing the mount. OEM windshields have HONDA on it at the lower corners of the windshields.
If your car does have a OEM windshield try pushing the clips down and then up to loosen the mount.
As for insurance. Try talking to your agent. Obviously don't tell them that you cracked it yourself.
Originally Posted by hzm82
If the crack isn't that bad, the glass repair people might just be able to patch it up. You might try calling them. Some insurance will pay for this too.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
dre707
09-08-2015 08:32 PM
