Michelin Pilots should only be used at 40-44 PSI!
#41
Guest
Posts: n/a
Re: 35psi Best Pressure!!
[QUOTE]Originally posted by tlsshopper
[B]
It says 44 psi max right on the tires.
[B]
Originally posted by EricL
The MXM4s are XL tires and the 1433 lbs load is available at 35psi. The XL rating and P designation (in front -- see link below) give the tire additional load "reserve" at the max pressure of 41 PSI.
Michelin Tech page for the MXM4 -- P215/50R17 XL (93V):
http://www.michelin-us.com/us/eng/ti..._pilotmxm4.pdf
_________________________________________________
Thanks EricL for the official word from Michelin on their recommended tire pressure of 35psi (refer to url above)! Based on other postings here, seems like most of us are also comfortable with 35psi instead of Acura's recommended 32psi.
Note: Went to a Jiffy Lube yesterday for a 5W-20 oil/filter change and they wanted to put 40psi in these tires; not sure where they get their specs.
#42
[B]
IMO, I think anyone who recommends a psi other than 32 and persuades someone to change their tire pressure is doing a disservice. After all, it's Acura that has done extensive testing to come up with their 32 psi recommendations. Did Michelin test their tires on a TL-S? I doubt it. Even if they did, Acura knows more about Acura's than Michelin does. No one on this board is a professional. Most professionals will tell you to go with the factory recommendations. That number will you give the best combination of safety and comfort.
[B]
#43
Re: Re: 35psi Best Pressure!!
I'm not taking sides on this and I don't want this post starting a Firestone/Ford argument. All I'm pointing out is the fact that vehicle and tire manufacturers don't always work together to come up with the OEM recommended PSI.
FYI, I run my TL-S OEM Michelin's at 34 PSI.
#44
Guest
Posts: n/a
#46
Originally posted by AKRY
To me, I would say Factory settings are ususally the BEST COMPROMISE(Ride/Handling/What not).... but not necessary THE BEST setting...
#47
Acura probably uses a LOW tire pressure because they want the car to feel smooth, but didn't want to spend the extra money on alluminum suspension parts and a firmer chasis. I seriously doubt its a safety issue. 32 is pretty low IMO. Easy to bend rims that
way (if you live in midwest).
#49
It was according to Boyle's law that when temperature increase, pressure increase. So if your tires are operating, its temperature increase. Same as its pressure. When your car is under normal operating temperature, your tire will be fairly hot (friction between tires and road) and thus, your tire pressure will be increased.
My cold temperature is at 28 psi. However, hot temparture is 36psi. If you guys have your cold tire pressure of 32psi, your tire will most likely be around 40psi under hot temperature.
neuronbob
23
07-16-2019 10:48 AM
