Maintenance By Time not miles
Motherinlaws 99 TL has only 30k but is over 8 years old. Found out nothing but oil changes and few recalls done on it so far.
I'll do some work myself, but need some advice.
- Coolant def needs change, but does Timing Belt need changing with only 30k ,even if 8 years old? Is timing belt a possible diy for only a moderately good diy'er? Prolly get this done professionally.
- Brake fluid: prolly get this done prof.
- tranny fluid: diy, 3x drain and fill. Any filter or other items with this?
- Plugs: diy, probably go with OEM from one of the sponsors here, HandA, or similar. Saw some recom. for iridium? Really looking for good mpg performance, long-lasting. Best option?
- Air filter: will try to get a permanent (cleanable) new Fram or K&N.
- PCV Valve?
- cabin filter, might check it and see.
Anyother tips or advice I should know about other than what is listed in manual? Thanks in advance!
- PCV Valve?
I would change out a timing belt that only had 30k miles and 8 years WAY before a belt with 200k and 4 years. Rubber and age arent a good thing. Its possible to do for a moderate DIY'er.
https://acurazine.com/forums/showthr...8&page=3&pp=25
Plugs stick with oem
cabin filter DIY
https://acurazine.com/forums/ramblings-12/i-love-tattoos-but-just-wrong-107821/
cabin filter DIY
2Poor 2Furious
also repeated cycling of hot and cold weather will degrade the rubber faster regardless of use so change the timing belt rather than taking the risk.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
Zonian22
09-02-2015 08:19 AM
