lowering my car...HELP!
Old 01-22-2004, 11:37 AM
Planning on lowering my car going for h&r sport spring running on the stock rims right now cause it's winter.Do i really need a camber kit? any rubbing issue with this set-up?cause i have aftermarket rims it' 5zigen fighter 17's 215/50 but when u put it on looks wider than the stock.and what about my sways do i need to change it?
Old 01-22-2004, 11:42 AM
Rock Star
nym31mp's Avatar
w 17's there should be no problem when u get to 18's w some there is and a lowered car w 19's will rub......
Old 01-22-2004, 11:49 AM
TL-S driver
goldendragon576's Avatar
it all depends on your offset of your rims. If your rims are +50, or more, it will fit right into your fender without rubbing. If you have +45 then there might be rubbing if you slam it. Cutting the tabs will definitely help. I don't know about the chamber kit, but from my understanding, you don't. Someone correct me if I'm wrong.
Old 01-22-2004, 12:09 PM
Tatewaki's Avatar
I've H/R sports. No camber kit needed. Just get an alignment done 2-3 weeks after. I have 18x7 +45 wheels. I had to roll fenders and cut the tab
Old 01-22-2004, 12:14 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
with the h&r and comptech drop you shouldnt need a camber kit. just an alignment. as far as rims, as long as its the right offset you wont rub at all. and no you wont need to change sways unless you want even more performance
Old 01-22-2004, 12:36 PM
i got 17x7-144.3 42 it means my offset is +42? so i'm okey.THANX A LOT GUYS ! what a great help....
Old 01-22-2004, 01:06 PM
my bad! so if my offset is +42 i got a rubbing problem right?but anyway thaks for the reply.....
Old 01-22-2004, 10:04 PM
lodoss22's Avatar
Sorry if this is a stupid question, but why wait 2-3 weeks after your spring installation for an alignment?
Once I get my H&R Sport Springs I plan on installing it right away and was going to do the alignment thereafter.
Old 01-22-2004, 10:26 PM
njtls's Avatar
your probalb yognna rud...on the border probably
Old 01-22-2004, 11:54 PM
Tatewaki's Avatar
All springs settle over time. You want the get the alignment done when it's all settled. If you do it right after. The alignment will be right for a while, then off again cuz the springs sagged.
Old 01-23-2004, 12:56 AM
lodoss22's Avatar
Thanks for the enlightenment. I will wait 2-3 weeks for the alignment test after installation then, thanks.
Old 01-23-2004, 09:03 AM
JPTLS03's Avatar
My 19's never rub.
Old 01-23-2004, 06:05 PM
Dragging knees in
Pure Adrenaline's Avatar
Originally posted by JPTLS03
My 19's never rub.
That's because you have Comptech springs with no system in the trunk. H&R Sports sit lower in the rear than Comptech.
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: lowering my car...HELP!
