Loose lighter/accessory socket
The accessory socket near the coin tray on my car is loose; it rotates and can be pulled out 1/4 inch.
I found the following thread:
https://acurazine.com/forums/showthr...lighter+socket
However, no one mentions what needs to be disassembled in order to get there. Can I get away removing the nearest side panel to do this? I assume there's a nut in back or either the sleeve is the nut, I can't tell from the parts diagram.
Thanks.
Thanks.
Fixed! An easy way to tighten it given the limited space is to tighten the sleeve by using a flat bladed screw driver and and hammer against one of the splines on the sleeve after you've gotten it finger tight.
IBankMouse
06-13-2020 12:53 PM
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
