loose exhaust
Yup as i recall when a Rub Hanger dies it make the muffler hang loose go to autozone and buy New ones. Urethane is for long lasting but it costs a bit More
B A N N E D
, and there are a total of 5 hangners that would give you issue, 2 for each muffler (one at the very back of the muffler, then the other one in front of muffler), then the very last one is in front of the gas tank right next to the resonater
btw to check the 4 for the mufflers, you do not even have to jack the car up, just crawl/slide right under (even an average weight person can do it), then the fifth one just look under the driver side (i think, might be passenger side though) right in front of the rear tire towards the center of the car, and you will be able to see it easily (flashlight might help too)
GGrid44 (02-01-2019)
Thanks guys, I'll give it a shot tomorrow.
About a month ago I installed a catback system for a friend of mine on his Mini Coop, and by the mufflers were a bracket with hex screws that adjust the position....(up, down, left, right for the muffler) Do our cars have that as well?
just plain ol rubber hangers
Stop by any exhaust shop and they can throw on whatever you need
May be an issue somewhere if ones broken--like getting bumped into by another car when parked can push the exhaust forward and bend the pipe! example from bimmer that was tapped by a vw and caused about $1000 damage that wasnt seen at the time- it kept breaking hangers and replaced at different shops so no one saw a trend..until the truth was told by the owner and the problem found, bent pipe and connector at cat-
B A N N E D
now on the other hand my car was F***ed cause it went underneth from being lowered
Heres a pic of the old exhaust, but see what I mean...
rest of the car
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
joflewbyu2
10-08-2015 11:16 AM
