Lighter Rims=More Wheel HP
TL Type-S Owner
I was wondering has anyone either done a run with new rims of the same size but weigh less, or dynoed their car with different rims. I am looking at moving up to an 18" polished aluminum, not so much for looks, but more for power gains. Any information on wheel HP gains with new rims whether it is for the TL or not would be great.
Retired MOD
1 Post
Re: Lighter Rims=More Wheel HP
hum... good question... I am not sure but here is what I know and what I think.
I know that if you upgrade from 16 to 19 you lose HP on the dyno. I think it's mainly because of the difference in size...
lighter rim will give you better performance, that's for sure... but will it give you a better number on the dyno... I think it will, too...
Technically, you don't lose or gain horsepower when you don't change any aspects of the engine. An engine with 350 hp will still have 350 hp, no matter how much a car weighs. Now acceleration will be improved, as well as braking, but not engine hp. As for the dyno, to get a true reading of engine hp, you need to pull the engine out and set it up by itself, and measure hp that way.
There are two ways changing rims will affect you car's performance:
First, it's not just the mass of the wheel (plus tires) that matters, but also its moment of inertia. remember that you have to expend energy to spin the wheel, and that energy comes out of the same bucket that pushes your car forward.
Second, changing the diameter of the wheel changes the moment arm at the axle, effectively changing your transmission's gear ratio. The larger your wheel diameter, the less force is available to push your car forward at the same torque output.
It's a linear relationship, so changing your wheels from say, a 18" diameter (including tires) to 20", for example, will change your radius from 9" to 10", so at the same torque setting you will get 9/10 = 90% of the original force applied to the ground.
Retired MOD
1 Post
Two questions:
Let's think both 16", 18"are the same total diameter.
Would the 18" have more mass on the outside from the center of the rim, if yes how much of a difference would that make?
If each 18" is 6 pounds lighter than the 16" with tires, how much power would you gain. Total weight loss 24 pounds. This would increase hp/weight ratio right ?
TL Type-S Owner
I hate to say it, but engine HP doesn't matter. It is wheel HP to weight ratio that makes the difference. If you have a 350hp engine that only gets 200hp to the wheels it is no better than a 300hp engine getting 200hp to the wheels. The deciding factor is the curve of the dyno and the weight. I read on a very distinguished site that going from a 28lb rim to a 15lb rim on a AWD Eclipse GS-T is a gain of 52hp to the wheels. This sounds to be about right. Meaning that a loss of 1lb at the drive wheels is equal to 1hp. Can anyone back this up?
Don't hold me to this but I believe I read somewhere that 1 lb turns into 4 lbs when rotating. So if you change from a 28 lb rim to a 15 lb rim, you are essentially dropping 208 lbs of the total weight of the car when in motion. (13 lbs x 4 lbs x 4 wheels ???) There is a equation where you can convert weight reduction to whp gains. This sound right to anyone.
Originally posted by Bitium
I don't think he is asking about diameter. Your point is releated to total diameter. If he goes to 18" from 16"/17" but keeping the original total diameter with a smaller tire, how would we answer these two questions.
The only difference now is the weight of the wheels and their moments of inertia. I don't know the typical moments of inertia for rims, so I have to plead ignorance in this case.
But typically, enlarging the rim diameter pushes mass to the outside of the wheel. In this case, the moment of inertia goes up significantly.
Two questions:
You'd almost have to measure the moment of inertia of each wheel to make a fair comparison. Wheel designs vary so much that I can't really predict the change with any accuracy.
If you are happy with your gear ratios now, choose a wheel and tire combo that are as light as possible but the same diameter as you have. If you are not having traction problems leaving the line or you want a lower final drive ratio ( higher numerically) buy a light combo that is of a smaller diameter. The Tire Rack can really help you with this part.
Just wondering, Dave are u a Phyics Major. I dreaded that I was gonna take phyics this year but I love that damn class. I have never missed or skipped that class.
that sounds about right. So while you are not increasing hp, you are reducing weight, more specifically the rotating mass, thus making your car faster down the 1/4..... Less weight is being pushed by the same hp.
TL Type-S Owner
I know you are not so much creating more HP but freeing up some HP to the wheels. My question is, will buying new rims give me enough time in the 1/4 for it to be a worthwhile mod. I don't care about the looks, and if I want better handling I can just get tires, but would rims be worthwhile in dropping my ET.
Yes, I had a 2000 Auto Maxima, stock dyno was 174 hp. I put 17x8 Momo Arrows on my Max, dynoed later, and got 164 hp stock!!! lol!
But after ypipe and intake, It dynoed with the wheels 184hp. All the same dyno.
lower profile tires are harder to lauch.... and to catch (get grip off the line)
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
